No guts no glory. I went ahead and did the Rough Country 1318 2in level. It was anything but level. It had had the front up an inch higher than the rear. So out go the factory AT4 blocks and in come 3in ones. Sits dead level now. Went with 35x12.50x20 Nitto Trail Grapplers. Was a little nervous since they measure and true 35in and 13.39 wide. A 1/4 spacer was needed on the front since the width of tire was causing a light rub on the upper control arms. Removed the mud flap bracket, trimmed the mudflap, and pushed and pulled the liner out of the way. No rubs, lock to lock now.
  • Like 4
Pics of the post surgery modification?
Did you go with the borla wheel spacer?
She still has the bandages on, but once they come off and she has time heal a little maybe.
I didn't use a wheel spacer or adapter just a Dorman 6 lug "shim" I picked up at the local O'Reilly's. 1/4in thick, worked perfect.
Awesome looking truck!! Do you have any side pictures?
How does everything look with the "Rough Country 1318 2in level" kit? I see that it's specific to the at4, but curious if it's the same as everyone else's level.
I started a chat with Kirk at RC, and he stated that the geometry stays perfect with this kit. Anyone?
Edited by mattsvtcobra
I'll try to get a few more side pics uploaded tonight.
The geometry was perfect. My alignment guy was shocked, a slight tweak to the toe and we were done. I think the idea with the 1318 is that the lift comes from more than one location. A spacer at the bottom of the spring and the shims between the lower control arm and the shock. Rather the just a big block at the bottom of the shock. When the say 2 in, they mean 2 in.
How was the CV and ball joint angles? I think this is the area of concern when going over 1.5” on the AT4/TB trucks.
Got any pictures of those?
CV angle looks good, close to LCA/shock at all?
I like the look of the 2” system better than the 1.5” system for sure. I just didn’t want to run the risk of blowing the CV or ball joints out at full droop.
1.5" Motofab
TB 18s on 35x12.50r18
2"
I think the last 2 are before the level and spacers spacersc6f8a891733a31a4438a493078b5d40e.jpg23cca75ac202bf6da9a612ed19e9a1a1.jpgf7b294684f63b16f552c04746d8e5f1f.jpgbeef1d58e3f54ad42a64864a2098a424.jpg40bdbff0e59feae337963c5acc9e5d88.jpg6d58fac1c44f0db404595bf33afd3e5a.jpg5418be8777989d6f1fd98b8acd1f0d27.jpg
38 minutes ago, Cody OTR/L said:
1.5" Motofab
2"
What size spacers did you use up front?
16 hours ago, Cody OTR/L said:
1.5" Motofab
2"
On 8/19/2019 at 7:28 PM, Mark Vyskocil said:
No big deal, but your installer installed the bolts upside down according to manufacturer's recommendation (instructions).  I cannot tell in the photo, as your pre-load spacer looks identical to mine, but I wonder if the spacer was also installed upside down (with the chamfer facing up) which resulted in the extra, unwanted lift.
My RC 1318 kit leveled my truck perfectly, within 1/16".  No biggie, angles still look good, and you got alignment.  Congratulations on your extra lift haha.
    daveishi
    daveishi
  • Who's Online   0 Members, 0 Anonymous, 1,166 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
