It doesn’t seem to matter where it was produced.  Mine leaked and it is US built.
Good to know, thanks!
Noticed mine was leaking a little a couple weeks ago, so I dropped it off and they said it was fixed.  Well after washing my truck yesterday noticed the headliner was very wet on both sides of the truck, so obviously not fixed.  Large spots about the size of a plate on each side.  Any idea where the leak is coming from, is it the spoiler?
If you push up the headliner , I bet you can see some type of a crack in the corners. More than likely your in for a new window the next time you go in
21 hours ago, Roger McKee said:
I am on my 3rd window on my 2018. The slider leaks where it meets the stationary pane. I was recently told taking it thru a car wash could be the problem.  I said thats not an acceptable answer. Looks like they have had problems for years and still have. I'm going to keep going back until its fixed. Be leaking since it had 4000 miles on it
The 19s And 20s have a completely different problem ours do not leak at the slider it is coming from the top of the entire width of the window not just the slider... and my f150 would have a few drops in the cab from a high pressure car wash only.. nothing like what we are experiencing
It’s coming from the top of the back glass because for some reason the plastic frame develops hairline cracks and allows water in .. just got mine back yesterday
Interesting that the write up is specific to the sliding windows. I’m still curious on the solid windows and if GM even has a write up on it. So far good but I’m dreading the day I look up and see it wet.
I feel the exact same way my friend! One more leak and I’m taking a loss and going to RAM
I did go in my settings and shut off the automatic rear defroster feature.. maybe it gets the plastic hot causing it to crack. Just pure speculation of course
33 minutes ago, BLK- 2020 TB said:
Really!! WTF
I would say it’s not anything like GMs problem. The 2019 rams did have an issue with leaking rear windows, and drain plugs not installed correctly for the panoramic sunroofs. But just from scouring all the ram forums the past couple weeks, the amount of complaints is nothing compared to this forum. They came out with a new window, which all the 2020s have and apparently it’s fixed the issue completely and honestly I haven’t seen one complaint for the 20’s
I really like my trail boss .. I can deal with a few minor issues but water leaking in my interior is where I draw the line.. if it leaks again I’m going 2020 rebel or 2020 F250
Edited by BLK- 2020 TB
Update.. truck has been outside in the rain for 12 hours and still dry .?
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 506 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
