On 4/6/2020 at 11:12 PM, 19TrailBoss said:
So in the process of replacing my headliner because of water staining from the rear window leak, I now have a leak from my front window... Apparently the front windshield had to be removed to replace the headliner. Oh, and my rear window is leaking AGAIN!!! My dealership has tried to reseal the original window, then the entire rear window was replaced, then the new rear window was resealed, and now I've discovered the leak yet again. I'll be calling back my Chevy corporate rep tomorrow, and possibly a SC lemon law lawyer depending on how the conversation with Chevy goes...74c0daecf705bbc99c6a290a05c065a3.jpg
Sent from my SM-G988U using Tapatalk
Why would they have to remove the windshield to replace the headliner? That's like trying to pull a tooth by reaching through your rectum. On a Silverado/Sierra or like on my old Avalanches it is done by removing the rear window, not the windshield as has to done with a sedan.
And evidently from the recurrent leak the rear window should have been removed for a proper repair and headliner installed through the rear access. And just a thought...a sunroof?.......if so may be a blocked drain tube in the "A" pillar which is where that leak would show up.........pop the threshold trim plate a windshield leak would show up as a soaked jute carpet backing and water in the wiring loom channel underneath.
Great info Thomcat.... When I brought mine in for the rear window they discovered the leak in the front.  The carpet was wet under the mat.  They figured out that when the truck was built, the sunroof drain line wasn't properly connected and it was draining on the floor similar to that picture.  Worth a shot...
It’s just the way it is, the headliner doesn’t fold and the only way to get it out and a new one in is to remove the windshield.
I have a 2019 RST with the same issue. I will be bring it back in for the same issue for the 3rd time. First time they tried to bandaid it when I was told it was being replaced ( siliconing or butyl from the outside) ?‍♂️. Second time I was assured that they would be actually be replacing the window. Third time all parties were irate. Dealership, body shop, window shop. Long process seeing as the headliner and cab spoiler need to be removed to access the window. Yesterday when I took it in for them to check for the third time and I brought it into the shop so they could hit it with the wand with the dealership and mechanic present so they could see and the mechanic said he thinks it's actually coming from the cab spoiler. Must not be sealed properly but it comes in at such a weird spot. Driver's side top right hand corner of the rear window. It comes in from behind the read window rail corner. Completely dry if you run your finger through the track but where it attaches to the window it makes a slow stream inside. Mechanic said I was lucky because one guy had it flood into the cab and destroyed his head liner. Let them know it could be the cab spoiler so you guys dont have the same headache IV had driving a loner for over a week total.
I posted just a little bit earlier, rear window might be the cab spoilers not sealed. In on my 3rd time in for a replacement
My rear window is getting replaced now, went in on 4/06, and still no word when it will be done. They are getting a glass specialist to install rear window, but the second they call me to tell me its done, its going to get traded in. Just don't want to deal with it anymore since people are still getting leaking windows even with a replacement. I drive too many miles and will be out of warranty very soon and don't want to be stuck paying out of pocket later down the road.
What will you trade it for?
You really want to trade it in now?  They know you want to dump it, do they'll lowball you, and there's a ever decreasing selection of vehicles to choose from to replace it...
He doesn't have to trade it in at that dealer.
the 2020 rams have my eye. Just got to try and stay away from the panoramic sunroof and the air suspension
22 hours ago, davester said:
6/You really want to trade it in now?  They know you want to dump it, do they'll lowball you, and there's a ever decreasing selection of vehicles to choose from to replace it...
yea i wont be staying with gm, looks like ram will be getting my business right now. Its sad to, ive had a chevy for every vehicle since i was 16. But they havent figured out the rear window thing and thats concerning
And the uconnect infotainment... We had it in our 2014 Jeep Grand Cherokee and it was glitchy and would go completely black from time to time.
I was going to say the same thing.
What about one with a solid rear window since it seems like there’s no issues
I've had tons of problems with the gm one in my sierra, goes black, changes volume, plays multiple sources at the same time and wont let me change anything. There are problems with uconnect for sure, but probably not any worse than the gm/chevy. Honestly I think its just luck if you get one from either company that actually works right.
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
