Mine's a leaker now, too.  2020 ltz built 8/19 in Ft. Wayne.  Took delivery on 1/11, 2000 miles ago.
Glass is a Fuyao E4, M1235, 43R 000072.
I caught it early, no headliner damage or rust.  I'm gonna try the permatex fix, maybe buy some time until GM actually fixes the issue.  Love the truck, wish it could be driven in the rain.  ?
I would bring it in to at least have a record of them seeing it leaking, you start messing around with this stuff yourself your going to most likely own it if you know what i mean.
  • Like 3
So after getting my window goop with Kent sealant, it’s leaking again.  But this time it only leaks after a long rain.  Survives a touch-less car wash however.   Wondering if anyone has a copy of the official instructions to lower the headliner?
I’d like to see maybe if I can spot the breach point add some more sealant.  I’d rather delay having to go back to the dealer until GM comes up with a more permanent fix.
mine not leaking after it got replaced, but a co worker with a 19 LT was telling me that he had some smoking/burning smell and noticed it was coming from the rear defroster electrical, and that's when he realized his was leaking also
My thought is almost every leak can be fixed with the Kent sealant (other than a cracked window frame) but it’s the incompetence of the techs that is leading to them leaking after this. If a proper bead was placed on the top seam of the window and then leveled out with a finger or dowel or something to make sure it spreads evenly and goes into any void it would probably work. The sloppy job by the techs with it just arbitrarily gooped along the window isn’t doing us any favors.
Like previously stated, I fixed mine myself with the permatex window and glass sealant which is a lot more viscous and goes into every nook and cranny - this is after I had the Kent sealant done by the dealer the first time.
Does anyone know if you have to drop the entire headliner, or can you just lower the back side to remove the roof spoiler and seal the rear window?  The GM TSB pics seem to show just lowering the back of the headliner. But it wants to hang up on rear window slide channel and I don’t want to crease the headliner.
Dealer said they couldn’t just drop the back of my headliner, wasn’t enough room to work without creasing it. So they took the whole thing down. Take that for what it is.
These are awesome, thanks Brandon. Do you happen to have any of these on the sunroof? After mine was repaired, assuming they dropped the rear of the headliner, the sunroof shade is scraping in the dome light area. Would love to see a diagram to see if it’s off the track. I have a borescope I am going to drop the dome light and see what’s going on in there.
While everyone is self quarantining they should watch “American Factory” on Netflix. It’s about fuyao glass company.
Quote
Just picked up my ordered 2020 LTZ crew cab.
Going to add a camper cap.
The question is to all those who have endured this leaking problem.
Would you add the flowable sealant to a new truck without a leak as added insurance for future problems?
Really don't want to have to pull the cap back off for a repair and with the cap installed you probably won"t see any extra sealant anyway.
After 125 pages, I am just trying to be proactive for a potential problem that truly seems be "Rocket Science " for GM engineers to solve.
Thanks
Mike
Thanks
Mike
I honestly wouldn’t touch it until it actually started leaking. There are a lot of leakers out there but it’s a small sample size of the hundreds of thousands of trucks out there. Who knows, you might get lucky and get a dry one!
hotrodz37
Thanks for your fast reply.
Guess I will let it roll as is and lean on my Irish heritage a bit.
Hopefully this is my last post on this subject. LOL
Good Luck to all.
Thanks
Mike
FYI if your truck has the camera in the rear brake light it won't work with the truck cap.
Sent from my Pixel 4 using Tapatalk
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,346 Guests (See full list)
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
