Had my truck in for the sealant job and not 36 hrs it was leaking again, rather than having the dealer try it again, scratch more interior panels or have to replace the window and scratch the paint etc, I decided to try something.
I wound up buying the Permatex window and glass sealant. Masked off the back window and ran a bead of it along the top of the window. The tip that comes with the tube is small enough to get in between the window and spoiler. This product is quite a bit thinner than the Kent sealant which is what I wanted to get down in every nook and cranny. Let it cure for 24 hrs before driving and waited a week to try the water test.
Time will tell but after dumping two 5 gallon buckets around the back window and spoiler it isn’t leaking at all.
I figure this probably isn’t a permanent fix, but if it can at least hold me over until GM comes up with a better fix or a new window design that doesn’t leak, it’s a win in my book.
Disclaimer: not sure if it’ll work for you and have no idea if it voids the warranty, but it is also clear and looks identical to the Kent sealant so given the non-detail oriented nature of the techs at the dealer, doubt they would notice. I wanted to have mine at least attempted to be repaired once by the dealer so it’s documented.
There was someone way back in this thread who used that flowable silicone and stopped his leak (think it eventually came back).. I was thinking of running some of that along the top of my replacement window as a precaution.
Sent from my Pixel 4 using Tapatalk
The dealership's glass company replaced my window today.  It took them about half a day.  They said that they have done quite a few now and none have leaked after.  They did a fantastic job.  Even returned my truck to my workplace for me.  Waiting a couple of days before I run it through the car wash.
Great to hear. Make sure you check the rear slider. They forgot to hook up the power to kine when they replaced the glass
Same here they forgot to hook up something. Now my rear defrost will not work.
Add another to the group. Now I have to find a dealer that can actually fix it.
Not sure on build date but i bought the truck early Feb 2019 and it just rolled off the truck; I have 9k miles. d11a4f273f44ed3224e7f67b0dabc3fa.jpg
Sent from my ONEPLUS A6013 using Tapatalk
Which one did they install as the replacement? FUYAU or VIRTO and the E# ?
We really need a sticky on the new window model number being used to replace the bad one.
First time posting. 06/19 Build rear window leak with bad staining in the head liner. Just noticed it today as I was getting my daughter out of her car seat.
Let the warranty journey begin!
Was just thinking out loud. What about getting some clear flex seal tape tucking it up under spoiler and press it against the back cap of the truck, down in the channel at top of window and up over the top edge of the glass. Then use a razor knife to trim the excess off flush with the glass. Not sure you could effectively do it with the spoiler on but it might be a better, less messy temp fix than caulk if you had the spoiler off.
If you could get that tape to stick real good along the entire length of the window top it would create a membrane barrier like on a flat roof.
  • Haha 1
  • Sad 1
It's a FUYAO E4
just use the spray:
  • Haha 1
12 minutes ago, PackerChev said:
It's a FUYAO E4
That's the one they put in mine when doing the replacement.
Image result for flex seal spray
Waterproof and Lasts A Lifetime!!!
  • Haha 1
Has your new one been leak free?!
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
