56 minutes ago, SamDSJR said:
For all you guys that have been posting recently (after page 80 or so....) Can you all post your build dates and model years as well? I (and my lawyer) who monitors this page would like to keep track of how bad the problem is (is it continuing into the 2020 model year.) I think it will help us all eventually. I know some people have said they have a 2020 leaking, and I know there's even a couple 2500 2020's leaking too.
2019 Sierra SLT. Built in Mexico 07/2019. Discovered window leak beginning of 02/20.
Entire window assembly has been replaced with the new updated window part number. Keeping a constant eye for any new leaks
Picked up my '19 LTZ Z71 yesterday from dealer for recalls and rear window leak.  They told me it was the spoiler but when I picked it up I ended up with a shitty sealer job along the top of the rear window.  They couldn't get the water stain out of the headliner so they have one on back order for me.
What do you guys recommend as the correct remedy for the crummy sealer job?  Can they properly correct it? Can the sealer be removed?  Or do they need to replace the rear window?  I assume taking out the rear window puts the window frame at risk of cracking (if it hasn't already).  Should I demand a new rear window when they do the headliner?  Appreciate any input.
At the point some of you guys are at i would fix it with a brick through the back window.:P
On a serious note, it sounds to me like your dealer is not all that good, talk to your service manager and if he finds the job you find unacceptable, well acceptable. Then my advice would be to go find another dealer to work with and yes a new window replacement is what i would be demanding for the simply fact it takes that work out of the hands of the dealer oil change tech's, as i believe a glass place would have to be used for install. Most likely the real reason gm is trying to fix this problem with bubble gum.
2020 Silverado LT Trail Boss.  September 2019 build (Mexico).  Purchased on 10 January 2020 and the leak showed up one month later right around 1,000 miles.
I've also got the leak on a 2019 AT4.  Took it to the dealer on Monday for recalls as well as the window leak.  The window is on back order so they had me pick my truck up while we wait for the window.  It's winter with no precipitation in the forecast so I'm fine there.  They have their glass department remove and install a new window.  Hopefully I'm good to go once they get the new window installed.  Side note - I did not have any damage to the headliner or floor.  Leak must not be as bad as others.  Also the headliner is black so it wouldn't show like a gray one would.
Some new windows are leaking as well. I drove mine about 25 miles before i discovered it leaking again. Currently waiting on another window. And I did have the new model window installed the first time around by a glass expert.
That's super frustrating.
Apparently he wasn’t an expert...
You are correct. I guess if he were an expert the glass would not leak. Same skill level as the robot that installed my window the first time on the assembly line. I should have said, installed by a glass company in town that has a very good reputation.
Update on my truck today after spending another 3 days at the dealership. Apparently SafeLite resealed my replacement rear window again today. When asked if they saw anything noticably wrong with the rear window or if they were just blindly resealing, the advisor basically told me they were blindly resealing it... Needless to say I'm not real confident in the "fix" and formally filed a complaint with Chevy to see what my options were. I believe I owe less on the truck than I could get at trade in, but we'll see...
Sent from my SM-G975U using Tapatalk
Someone on the Facebook group joined the rear window leak club at 42,000 miles on a denali. Now to pay for a window caulk job outside of warranty. THAT really blows twice as hard498a7a682d27968cf54ee56c1cda4e00.jpg
Sent from my Pixel 4 using Tapatalk
  • Sad 1
Which Facebook group.
You can add me to the club. 2019 RST 4/19 build date with ~15,000 miles. Taking my truck to the dealership tomorrow. Took a bunch of pictures today so if something looks bad when they finish I can show them and ask them to fix it. Absolutely love this truck except for the leak.
At that point i would be trading it in, taking a loss, and never looking at gm again. Yes most dealers will tell you to pound sand once you are past that 36k, it will take years of fighting like the brake booster issue and how many were out a grand plus fixing that flawed part.
Okay fellows, I got a new one for you, have not heard this until I just got a phone call from the dealership. My truck is sitting at the dealership after finding water pooling up in the sliding glass track, after just an easy hand wash, enough to completey soak a heavy duty paper towel. This was a couple of days after my new window was installed. The service manager just called and said, yes, you are correct there is water coming in at that area, but it is going no further and is draining back out. He said he did several water tests on my truck,  tested several others  in the service department and a couple of new ones sitting on the lot. all of them did the same thing. He has done a Field Product Report and submitted it to GMC. He still could not explain how my carpet got wet, but assured me my carpet was dry after all the testing. So, I asked him, what do I do now? Come get it and hope for the best? And of course his answer was yes. Not feeling very confident, but I am very close to lemon law in my state and have my lawyer ready to roll if I hit the requirements. Stay tuned.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
