Remote start...heated seats
Am I being stupid? So in the settings, Remote start auto seat warmer is turned on. However when I remote start, the seats don't appear to be heating. No lights are on in the switches. On my 09 Silverado I could see them lit up.
Once I get in and start the truck, hit the button for them, they seem to turn on. Am I missing another step or something else thats obvious?
And before you ask, yes it's cold out. -10C/14F today.
10 minutes ago, silveradosid said:
lol thats not cold it was minus 21 here and i dont have heated seats but i do have remote start at least
well, yes, that's colder. But its still cold. Especially when you factor in the windchill.
I confirm. No heated seat lights on remote start but both my driver and passenger are warm to touch. Once I turn key then have to manually turn heated seat on.
My heated steering wheel won’t heat in remote start. Is always ice cold until I hit the button.
I don’t know how fast they heat so they might not be warm yet if you get in the truck soon after starting it.
My experience with this (I haven’t read anything in the manual that confirms it) is that the seats ARE heating but you won’t have any lights. Once you insert the key and turn it on, the seat heat shuts off and you have to turn them back on with the button if you want the seats to continue heating.
As long as I remote start and wait several minutes, the seats are definitely warm when I get in the truck.
Thanks folks. I do think they don't heat as well as my 09 silverado. Unsure if they have something wrong with them or just how they are.
Either way, good to know its just the light not on. :thumbs:
I do 2 cycles of remote start and the seats arent as warm as i think they should be so i think sitting on them gets them warmer faster vs not sitting on them.
Manual has good information on this topic.  It speaks about unoccupied seats and enabling this feature in your personalization menu (3-10 in my manual)
Heated seats are very weak on the 2014's on up. Barely feel any heat out of mine. Especially the bottom cushions. Also had to have both bottom ones replaced recently. Failed right after warranty ran out too. They are building these trucks as cheap as possible yet wanting over 50k for a new one. Sad times in the truck world.
@Roscopcoletrain Thanks for asking this, I was just headed here to ask the same.
@Ed S I see the opposite.  My seat warmers actually get pretty hot.
The remote start heated seats do not turn on and light up like they do when you put the key in and hit the button, they are designed to turn on but much more subtle just to break the chill.
On mine it doesn't matter, with remote start or with the regular key start and run. Not much heat at all felt out of them. Barely warm.
The seats on my Trail Boss get very warm, first vehicle  I've had with heated seats and I love them.
    • The Germans basically didn't make the list. There aren't a lot of shade-tree mechanics who work on them in general. At some point the economic equation of keeping a car alive favors junking it. Anecdote/experience tells me this is the case versus actual bad engines/engineering. Not that there isn't any, but there are definitely notable excellent examples. The 2.0 diesels will go forever and ever if one keeps the car around it running. The 2.0 gas cars eventually wear out their turbos but the block below it is usually still solid as a rock. BMW inline 6's same thing. Mercedes diesels of yesteryear, not uncommon to see 250k out of those engines, easy.     Link to the synopsis of the study: https://www.iseecars.com/longest-lasting-cars-study
    • 0w20 is recommended in the Sequoia. 0w16 in the Highlander Hybrid.   I think you make a compelling case for both the quality and frequency of maintenance but I wouldn't go so far as to plot a linear relationship between longevity and oil weight 😉   The list is interesting and leaves me with some questions. The Silverado 1500 is 12.9% likely while the GMC Sierra 1500 is only 10.8% likely. Arguably, they're the same truck, so other factors must be influencing the outcome.   The Honda Odyssey ranks #12 at 13% likely. Great. Rest assured we'll never stop hearing about the dang thing LOL.   There's a bit of a spread between the 4Runner (32.9%) and Tacoma (25.3%). Both overlap on the same 4.0 for many years although the Tacoma used a 3.5 for the last 10-12ish. I wonder if that's related to use-case or if it's suggesting the 3.5 isn't quite as up to the task, or maybe something else fails mechanically.   Ram at 3.5% overall likely, but the Ram 3500 holds the top spot on the Heavy Duty Models at 39.7%. One might say the Cummins is a ringer and provides an unfair advantage. I don't think it's fair/accurate to pit the GM Fullsize 1500's in a list with HD's which are basically medium-duty wearing a 3500 badge.   The Tahoe and Suburban hold spots #15 and #8, respectively, on the longest lasting SUV's list. What's the difference? One's got a shorter butt, unless they're also counting the 2500/3500 Suburbans in those numbers.   The GMC Canyon gets a 1.4% increase over its twin brother Colorado. Why, because it's prettier?   SO many questions...
    • Have the aftermarket system removed an re-test.  Its pretty much the only way to know if there is still an issue that is the truck and not from that.
    • Yeah they all have break in procedures I completely ignored in the past. During tests drives I would test them out. It seems today they’re sensitive so it’s probably a good idea to follow the procedure. The other would be changing the oil more frequently in the beginning.
    • Thanks for not getting back to share your findings...  🙄
