That's not what my noise is. I had the vent hose replaced and it still does it. I believe it's the Z71 badge on the front left fender.
Sent from my Pixel XL using Tapatalk
Another reason they should have never put these on the front fenders, and should have left them on the rear! :D
I have a strange one ...a whistling sound coming from the drivers side area... I thought Mirror air whistling ..nope..I thought under hood ..nope..I thought Badges on side ..nope...I turned off the ac ..almost a never situation in SW Fl... and the noise stopped..turned ac on and back it came ..turns out it is the upper console drivers ac vent whistles with higher speed... crazy...
Try putting your truck in auto 4wd mode when you hear the sound and notice if it disappears.
  • 3 months later...
The noise in my truck goes way when I put it into auto 4wd. What would this indicate as the problem?
I have a 2019 RST with the 5.3 two wheel drive. I believe the sound I hear is some kind of radio ground noise. It goes away with volume all the way down on radio. I wonder if there is a fix.
It is a problem with the front axle on the driver side. Check out the "jingle jingle only in 2 wheel drive" thread. There is currently no fix for the problem.
  • 4 months later...
I will have to discuss this with my dealer, I too have this strange high pitched harmonic type noise.  I haven't been able to pin point where it was coming from since I am hard of hearing, my kids hear it.   If I left off the accelerator it stops immediately.   Not too hard to duplicate the sound.
My Truck was repurchased for this issue it’s a problem with the front differential and the drive shaft on the drivers side. Find the jingle jingle in 2WD thread in the trouble shooting section it’s over 60 pages.
Edited by ILSilverado
  • 6 months later...
Did you ever find out what the issue was here? This sounds like a very similar issue that I have in my 2020 Silverado. Just picked it up last week and I already hear a metallic/harmonic sound when accelerating.
Sorry for resurrecting an old post. I thought I would ask here before starting a new thread. Going back in for the 4th time for this issue and was wondering if this repair has held up long term. I was thinking it was 8spd trans related. For my truck the noise is only noticeable at certain transmission temp. Yes it sounds like Rudolph's nose. The dealer has reflashed the TCM, performed a cleaning of the trans mount, and performed bulletin #19-NA-121 pertaining to trans fluid.
The noise persists. It is marginally better. Better mostly around the city but still pretty brutal on the highway.
So, wondering how #19-NA-005 fuel tank filler pipe has been the long term cure.
thanks
Sal
Mine did the same thing when accelerating and the whistle would go away when I let off the gas. It was the flapper valve in the exhaust. I wired it open and the noise went away and hasn't came back.
I realize this is an old thread. But I was having a similar issue with my 2019 Silverado.  Took it in and was told it was the “idler” they replaced it and no more high pitched whine.  Hope this helps anyone with the same issue
  • 5 months later...
I have the same noise on my 19 RST Crew.  I have had two dealerships drive it.  One said it might be a bearing ( to me it doesn’t seem like a mechanical noise, the other said needed new tires and alignment.  I have had it aligned at 22,****** miles already.  Both said no bulletins where put out on it.  Very frustrating.
I’ll bite. I have more of a whirring/whining noise at 60-65mph. Getting annoying. Does not sound like a whistle or high pitched at all. My brother say it sounds like the front differential but I’m in 2wd. Or heavy mud terrain tire sound. Anyone else?
    daveishi
    daveishi
  • Who's Online   1 Member, 0 Anonymous, 1,081 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
