Towing ATV ON 5x9 Trailer
Just got a 2017 Sierra All Terrain and haven’t towed anything yet.  Got a Polaris ATV on a small utility trailer should I use tow mode.  Will have some hills to negotiate my gut says yes.  Any thoughts please and thanks
4W
Personally I wouldn't mess with it for such a small load.  But just play with it and see what your comfortable with.
I personally don’t think I would use tow/haul for trailering that load.
The truck will not perform much differently with that trailer.
Why not? It will hold the shift points higher, which is a good thing for the hills, so it's not shifting as often. It will also give you grade braking too.
I know it's not much of a load, but some people run it with out a load due to the higher shift points......
Sent from my Pixel XL using Tapatalk
Think I’m just gonna play with it and see how it feels and reacts.  Thanks all!
I tow a cargo trailer up to norther Ontario Two ATV's and cargo.  I only turn the tow-haul on once I get the hills up north.
Keep an eye on the Trans temp. The hills are the only point in the trip it starts to go up.
Now when I have the 6300lbs  travel trailer on I use it ha ha.
Is a 5' X 9' utility trailer large enough for your ATV?  I have a Heartland 6.5' X 12' single axle utility trailer (2990lb GVW) with a Dexter 3500lb axle and use it to haul
among other things my John Deere X728 4WD tractor - 1100 lbs.  The trailer has a drop down gate - very heavy duty - maybe 200lb.  I find the extra size is nice for
using the tie down straps and moving around the load.
http://www.heartlandtrailermfg.com/
http://www.hotrodtrailersales.com/heartland-single-axle-trailers.html
http://www.macscustomtiedowns.com/
Unless your manual says otherwise, Tow/Haul is really only effective when you're above 75% of your GCWR and was designed that way.  Personally, I do not like the way mine shifts in Tow/Haul when the combined weight is under 9-10K pounds.  Above that, it feels and runs great.
Driving around Colorado I use Tow/Haul when towing my 3500 lb. boat.
It helps with the grade changes IMO.
8 minutes ago, L86 All Terrain said:
Put it in the bed and leave the trailer at home? Or your bed is full of coolers and gas?
Yup bed is full of my deer hunting stuff.  That being said, I think I will use and see how it feels, especially in the hills out west of Fort Worth.  Thanks all!
Yup its a Polaris 500 HO so it's perfect.  Prolly not big enough for a UTV.  I will give those a look but this one is homemade and built like a truck.
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
