33 minutes ago, TenshiWingusu said:
I hear ya. I would check the resistance on the new switch in both positions, you can force the latch closed with a screwdriver then pop it with the interior hood release. If the switch is in the spec mentioned above it's either bad wires somewhere or the control module has issues.
Yeah hey. I wonder if the dealership can silence the alarm that would be perfect as long as theres no ringing id be happy lol
Do you think if I unplugged that sensor and got a aftermarket remote start would it work? Or would the aftermarket remote start still need to know that the hood is closed so would have to stay plugged in
Can someone please show me a wiring diagram and pins on bcm. This truck got in a wreck and has a different wiring harness, but came stock with a hood switch with no pigtail
  • 5 months later...
What model year truck do you have?
I have a 2008 Chevy equinox that the factory remote start stopped working on. No service engine lights. No indication that a door or hood is open. I’ve changed the gas cap and even checked the tire pressure even though no lights indicated such problem. However I’m still having the same issue. The remote start won’t start the vehicle. The key fob locks/ unlocks the vehicle any and every time a button is pushed. Even illuminates the light when attempting to remote start but it’s like the process just stops. I’m lost definitely could use some ideas and can’t afford a garage to fix it.
One evening my 2018 stock alarm went off...I thought I must have hit the panick button on my remote...
The next morning I could not remote start the truck...
I get in, start it, and my hood open message was on with my check engine light...I checked the hood several times and it was opening and closing as it should...
Searched and found this post, measured the resistance between the black and red wire on the hood sensor connector and it read 529 ohms ope or closed.
Replaced the hood sensor and it fixed the open hood message and then I had to clear the code...
Tempatures were in the 20's to 30's and I had 51,000 miles...Makes no sense.
Hey Everyone, just had this problem on my 2018 Silverado LT. I think i found the issue. If you go to the hood with it closed and push down lightly on the hood even with your finger it will have some play. Open the hood, there are 4 rubber "standoffs" i'll call them. They keep the hood a certain distance from the plastic cover on the inside. turn them to the right they go down, turn left they stick out further. I just loosened mine so the hood would stand off the truck a bit further this makes the hood engage the latch more to hold it down. I think that movement of the hood was making the sensor think the hood was open because there was no pressure against the latch from the hood.
On 2/17/2019 at 1:57 PM, Linden16 said:
Yeah its the whole late assembly correct. So i installed that and still have the same problem yup.. not sure what else could be causing it. And like i said it only rings when the trucks cold. After a few minutes of driving it stops
Hey y’all just wanted to post that I tried the resistor and it worked!  I bought 2.2k ohm resistors off Amazon and soldered it in.  I was getting +\- 520 ohms with the hood open or closed so I knew it was the sensor.  Thanks for posting!
Edited by Jason56
Can you post a link to the resister?
Thanks
Jim
The resistance values (ohm's) stated earlier in the thread are correct, ~740 and ~2.2k ohms for opened and closed respectively. The linked 2.2k ohm resistors should work fine bypassing the switch.
For anyone having the issue, GM has a TSB out for this specific issue as well, regarding loose/bad grounds. If the resistance values of your hood switch are within spec. You may have a bad ground.
In my case it turned out to be caused by the ground braid (labled 3). Under the hood on the drivers side firewall. It is a thick braided flat steel cable bolted to the body cowl, bolt was lose an jiggled around. Throwing hood sensor codes (short to battery & open circuit). You may need to check the opposite end of the ground braid as well on the left rear cylinder head.
https://imgur.com/a/kddguGK
I have a 2014 Sierra Denali 1500. The hood open alarm comes on when I have to much going on inside the truck, for instance if I have my AC full blast and AC seats (passenger/driver) going all at the same time the alarm will start to chime. I unplugged it before and it stopped. I was able to continue as normal. I am not to sure if it’s just the hood sensor or if the problem may go deeper, like to the BCM. Can anyone let me know if changing the sensor out would be the fix?
Thanks
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
