Void 84/100 Platinum Warranty?
alkrisma
I just got a brand new 2018 Sierra SLT 4x4 5.3 and want to install (myself) Borla S-Type cat-back and K&N cold air intake but the dealerships service department said if it’s not dealer installed I will void my 84/100 platinum warranty?
That’s not correct. That’s their diarrhea of the mouth sales talk. Call up and ask the service manager, ask for his name and take note of time and date. If he says the same thing then call another dealership. You cannot be denied warranty on an install based on not having it done there but somewhere else instead. If you do take it somewhere and the installer screws something up well then you’re responsible.
Sent from above
Sent from above
X2
Dealer does not decide what is covered and not covered GM does. And what he said is BS. I know other dealer would say well if xxx dealer did it then we aren't warranting it. Call crap. Install yourself and enjoy.
I’m guessing your talking about an aftermarket warranty or the GM extended warranty.  If that’s the case an exhaust or intake could lead to a denied claim.  Your best bet is to call the ext warranty you have and ask them. Extended warranties can be forgiving if your upfront.
If your really worried about it get the GM borla exhaust and GM cold air intake then you won't have anything to worry about.  Otherwise just do it, they would have to prove those mods caused any problem.
It’s the GM Platinum 84/100 warranty purchased from GM dealer. What’s ridiculous is GM sells the Borla exhaust as an OEM accessory.
It always comes down to lawyers. If you read your contract under Exclusions, section "F", alterations void the contract unless recommended by the manufacturer. Or so it seems. Where does that leave you? I don't know, but I feel it is just a way for them to get out in an extreme condition. These new "GM" warranties are not actually run by GM. They are run by aftermarket warranty and insurance companies. I've never saw a claim rejected for mods in 36 years dealing with aftermarket warranties. Most claims are just called in by a service writer. Big $ claims usually require an adjuster be sent out. Most of the inspectors are pretty good to work with. If it was me, I would put the GM intake and exhaust on and not worry about it. Now a 7" lift may be a whole other matter. As with all contracts, they are written to protect them, not the end user.
I'll say my 2 cents. I had an 2014 Silverado. The dealer itself when the truck was new before it hit the lot installed a 6" lift, the borla exhaust you speak of, painted to match fender flares and 22" wheels. I also installed a k&n oil filter when I changed the oil I was the 2nd owner and only put about 6k miles on it myself bit it was still under factory warranty. I live in PA. This dealer was in Ohio. At 24k miles the engine blew. Naturally I had it towed to a local Chevy dealer. After a few days I was told it cannot be repaired due to the modifications on the truck which by the way were done by a Chevy dealer and cause of the k&n oil filter. I was then informed that they had GM put a warranty block on the truck. So I then had it towed to the actual dealer in Ohio who did all the work. I couldnt get anywhere with GM on my own. That dealer tried and tried and couldnt get the block removed therefore they had no way of doing any repair under the warranty. After sitting there for a month I again had it towed to tje garage who does my inspections back here in pa. Out of my pocket I paid $5200 for a used engine with 17k miles on it plus his labor time. I then had to hire a lawyer to fight GM. I even had to send my K&n oil filter back to them so it can be tested to prove it had No failures. They sent the test video to me and the lawyer as proof it was good. Eventually I got my truck back. The lawyer got the warranty block removed and got my $ back for the engine plus her legal fees. In the end it was a pain. If I would of taken it to the dealer in Ohio to begin with this wouldnt of happened. I traded the truck shortly after since gm wouldnt honor the replacement engine for any warranty on it only rest of truck. The dealer I got it from felt bad and gave me almost what i paid for it on trade. So I upgraded to a used sierra slt allterrain with a 6.2. Which I love. In the end it comes down to the dealer and what they decide to do. If you do decide to have them do the work just be sure they will honor the warranty after the fact.
Sent from my VS995 using Tapatalk
Read the fine print of the warranty your purchased and agreed to.  Extended warranties are more like insurance policies and the Insurer (warrantor) can put in exclusions (and deductibles) as to what they will cover and pay for, so again, read it thoroughly.  Many consumers never read them and come away with the notion that everything is covered when in reality its not and they agreed to it when they made the purchase of the warranty.
I have a 1 yr extended warranty on my 2018 Polaris RZR and the fine print states the warranty IS VOID if the RZR is modified in any way or if any accessories installed are not Polaris and done by an authorized dealer.  I was aware of this when I purchased the warranty and had no plans to change anything.
Its like what happened to many around here this summer in flash flooding. They soon found out that their loses where not covered by any home owners insurance. Needless to say many had no idea they had to buy special flood insurance and that it was not even offered by any company for this area due to once in 500 yrs chance of flooding. Now they have to apply for FEMA low interest loans and 9 months later, still waiting for decisions.
Did they say what the denial was, or all the above? The only thing mentioned engine related was the oil filter that was found in working order. The lift has nothing to do with the engine. The drag created by the lift is within towing limits.
I think in my case the 1st dealer I took it to just wanted to be jerks about the issue and use the alterations as an excuse to get out of the repair
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
