The "Catch Can" Explained - By Elite Engineering
With all the talk about Catch Cans, we thought it would be a good idea to combine the information into a smaller thread here.
To better understand the purpose of a good quality PCV Oil Catch Can and why they are important, we need to first understand the purpose of your Stock PCV System:
The PCV (Positive Crankcase Ventilation) system on your engine is designed to regulate and remove fumes from the engine crankcase, and to alleviate crankcase pressure which could cause oil leaks or seal damage. It’s a way for gases to escape in a controlled manner from the crankcase of an internal combustion engine.
During normal operation of an internal combustion engine, there’s a compressed air and fuel mixture inside the combustion chamber that is ignited and as a result, forces the piston down. A small amount of that ignited mixture leaks past the piston rings and ends up in the crankcase.
This leakage is often referred to as “blow-by” (leakage past the piston rings), as well as oil mist. Some of the oil mist and other products settle along the engine intake and over time form a “gunk.” The oil catch can collects the oil mist and condenses the fuel vapors while allowing “cleaner” gases to be passed back into the intake.
If these contaminates are kept inside the combustion chamber, they will eventually make their way into the oil inside the crankcase and cause oil contamination and dilution or make their way back into the intake manifold.
This problem has been documented in many automotive magazines, Car & Driver had an article covering this topic (Carbon Deposits with Direct Injection) There are hundreds of images on the Internet of Carbon Build up on Intake Valves:
http://www.gm-trucks.com/forums/topic/154204-oil-catch-can/?p=1608015
The purpose of a proper oil separating Catch Can is to route these gasses through a baffle system that provides the most contact possible with the outer surface resulting in the oil being trapped and removed from the other gasses that do continue on through the intake and are burnt and consumed. Typically the trapped oil is captured in the bottom of the Catch Can.
If you do your homework, you’ll find a lot of good Catch Cans on the market. You will also find a lot of products that claim to be Catch Cans but have no internal design or baffling to create the optimum amount of pressure drop to pull the oil out of the vapor.
Many Catch Cans on the market are just comprised of an empty container with 2 ports. While that simple design may trap a few oil droplets, a well-engineered Catch Can is designed to condense the oil vapor and trap the oil inside the container.
As I said, there are a lot on the market, go with a company you can trust.
  • Replies 698
This is my third Elite catch can. They flat out work with no issues. Great company to deal with and excellent customer service. Attached is a picture of my catch can after only two hundred miles. The truck had 1500 miles when the can was installed.
So please prove to me before and after pics of a catch can keeping valves clean...
What happens when that catch can fills all the way up?
You have to empty it periodically before it fills all the way up.
The difference between a "catch can" and an "air/oil separator system", as used on a number of OEM vehicle applications, is the drain back to the sump.
If GM had put a catch can on a vehicle, we'd hear cries of being tossed back into the 20s, when you had to grease the rocker arms before running your engine. A catch can is fine for the race cars and street rods, and even the meticulous street gear head. It's not something you want to forget to service.
I chose to buy a separator type with a drain back to the sump. This is an OEM type product that needs no routine intervention to drain. In addition, it has protection from overpressure with a bypass valve as well as a crankcase pressure regulating valve for supercharged engines. These types of systems are used on numerous OEM installations, including BMWs to large turbo-supercharged diesel truck applications. http://www.grupoherres.com/v3/intro/boletin/mann.pdf
https://www.mann-hummel.com/en/corp/products/crankcase-ventilation/
If you believe all the stuff we're seeing is oil in these pictures posted on this forum, their oil pans would be empty before the OLM change period. The fact is that much of what we're seeing in these pictures is a large quantity of water condensate mixed with oil.
You should research the various products out there and chose for your application, situation, and as importantly, your lifestyle. My lifestyle is to expect to use the truck like GM intended, with a similar maintenance schedule. That doesn't include remembering to drain a catch can. YMMV.
Spurshot - would you be willing to post a couple of pics of how you installed your separator? I've been piddling around with the idea and like the price point and what I'm seeing from Mann-Hummel. Any issues with installation or function? Thanks
Look on the bottom of these installation instructions, this is how we connect the Clean-Side Separator.
http://www.eliteengineeringusa.com/content/Catch_Can_Install_Chevy_GMC_2014_5.3L_6.2L_Truck.pdf
I've already installed the Elite Catch Can and am happy with the results so far. How important would it be to add the clean side separator in addition to the can? How much oil gets by with just the can?
OK, so I'm going to ask the obvious (and maybe stupid) question...
If this is an issue, why aren't catch cans and/or oil/water separators installed from the factory on every vehicle?
If the manufacturer can clear the powertrain warranty without issue, why bother (from the manufacturer perspective)? These are just to hopefully help us owners who want to extend the life of the engine and keep it as close to a new engine as possible
Virtually all vehicles have some type of air-oil separator in the PCV system. Most are simple baffle/labyrinth style. Some are very sophisticated. Nearly all will have a drain back to the sump.
I recall a round breather cap style with a hose bib on an early 60's car my father owned. It had baffles and drained back into the rocker cover like the RT and Elite "clean side" caps, but it went to the PCV valve.
PARTS-MASTER-14075-Crankcase-Breather-Ca
The foreign cars seem to have more sophisticated centrifugal or filter type separators. The American engines seem to have the least efficient/effort designs.
Still not seen evidence this actually keeps di intake valves clean like they all advertise.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
