15 minutes ago, ChuckTaylor said:
That one is pretty heavy with the offload and premium plus.  Interesting that tech pack isn't available on the SLT though.
Yeah that's an odd one. You would think an SLT should have access to that feature.
Edited by HondaHawkGT
  • 7 months later...
There is not a "typical" sierra.  It varies with engine, 4wd, bed length, cab length and other options installed on the truck.
Ok. Looking at the 1500 with 4wd slt  model with short bed. Diesel engine. Also, does gmc account for passengers or gas like Toyota does with the tundra?
My 2019 LTZ with the 6.2L and max trailering package has a payload capacity of 1910 lbs.  Compare that to my 2016 LTZ with the 5.3L, which has a payload capacity of 1572 lbs.
2 hours ago, imperialhipster said:
What is the typical payload for a 2020 1500 Sierra and does it include passengers or gas?
Payload capacity is for an empty truck with a full tank of gas.  It does not include the driver or passengers.  You would need to look at the yellow sticker on the driver's door jamb to determine the payload capacity of any specific truck.  The more optioned out it is, the lower the payload capacity.  Getting the Max Trailering package adds 200 lbs to the GVWR, which means increased payload capacity.
Edited by AlaskaErik
21 minutes ago, AlaskaErik said:
Payload capacity is for an empty truck with a full tank of gas.  It does not include the driver or passengers.  You would need to look at the yellow sticker on the driver's door jamb to determine the payload capacity of any specific truck.  The more optioned out it is, the lower the payload capacity.  Getting the Max Trailering package adds 200 lbs to the payload capacity.
Hey. Just checked and GMC Does comply with the standard, J2807. This means the payload  number on the door jamb does account for 300lbs worth if passengers and a 70lb hitch.
Where did you get your information from?
Edited by imperialhipster
My uncles 2020 AT4 fully loaded sticker was 67k I believe,  Payload is 1396
Think about it.  How can payload capacity that is specific to each truck include arbitrary weights?  And people will not necessarily be towing, so why include a 70 lb hitch?  This is the payload sticker from my truck.  Read the definition of what counts as payload.  You're confusing max tow rating with payload capacity.  They're two different things.
  • Haha 2
2 minutes ago, AlaskaErik said:
Think about it.  How can payload capacity that is specific to each truck include arbitrary weights?  And people will not necessarily be towing, so why include a 70 lb hitch?  This is the payload sticker from my truck.  Read the definition of what counts as payload...
You should read the standard the poster mentioned. There is a reason why automotive manufacturers adhere to it.
calculations for trailer weight ratings: In addition to the performance standards, SAE J2807 also uses a specific set of assumptions to calculate maximum trailer weight ratings:
  • For light-duty full-size pickups (GVWR < 8,500 lbs.), SAE J2807 assumes that the tow vehicle includes any options with higher than 33 percent penetration;
  • It assumes there is both a driver and passenger in the vehicle, each weighing 150 pounds;
  • It assumes that tow vehicles also include up to 70 pounds of aftermarket hitch equipment (where applicable); and
  • For conventional trailer towing, SAE J2807 assumes that 10 percent of the trailer weight is on the tongue.
https://www.sae.org/standards/content/j2807_201602/
learn something new everyday
That isn't the payload sticker - that is the tire pressure sticker.
The serial number of the truck is on the sticker.
The pressures listed are for the tires that were installed on the truck.
There will be a second sticker on the door post.  It is also printed specific to the vehicle/serial number.
Down near the bottom.  Easy to miss.  (other posts have pictures of the payload sticker)
Similar to the tires pressure sticker, they know what options are installed by serial number and establish payload from those numbers.
Any accessory added at dealer or by owner, that wasn't on the factory order, is considered 'payload'.
SAE is a standard used to measure towing capacity for trucks (and cars) with a payload of less than 14,000 payload (up from 13,000), not a rule or law but a voluntary standard. It just puts everyone on an equal footing so the consumer can compare towing capacities among vehicles and not have one manufacturer exaggerate their claims.
Ford finally agreed that it would use the J2807 on new or redesigned trucks so the F-150 for 2015 is certified for J2807 but not previous models. Toyotas are certified starting in 2013. Ram and GM 1500-series pickup trucks were certified to SAE J2807 as soon as it was clear that Ford was going to follow through. Nissan is the only holdout at this time.
Standardized Tow Rating Procedure Finally Gaining Traction | Edmunds.com
All the unrealistic test weight practices of the past that led to asterisks and fine print have been eliminated. Maximum tow ratings can no longer be based on a stripped base-model truck with a 150-pound driver traveling alone. Test trucks must now be equipped with popular options found on 33 percent (or more) of the configuration being tested. The 150-pound test driver is now accompanied by a 150-pound passenger.
Cars.com has an article on this as well.
I hauled a pallet of retaining wall block. Kept it under 45mph. Only went about 10 miles with it. Total weight was over 3000lbs. Truck did fine, no bottoming out or hitting the bump stops. Stock trailboss crewcab.
Again, you're quoting the standard for max tow rating, not payload capacity.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 290 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
