On 2/12/2019 at 11:50 AM, O Town Denali said:
I never use AM/FM either.  Have taken off the antenna on last 4 trucks.  Cover with rubber cap.
where would one get a rubber cap like this ?
My '86 GMC version of the Suburban had the antenna built into the windshield.  I remember at the time a push for GM to return to the traditional mast type antenna!  The reception is apparently superior with the exposed "coat hanger".  (Broken antenna's are often temporarily repaired with a metal coat hanger)   Another advantage is these antennas serve as an early warning device for low parking garages. ;-)
I like the antenna for this very reason. If it touches the height pole going into the deck, then I know I know I'm not going to fit in the deck.
Since our 6 3/4" and 21" antenna products have been mentioned here, I will throw out there if you have any questions feel free to email or call with any you may have.
We stand behind our antenna products and if you're not happy with the option you went with we encourage to contact us to exchange to a different option or simply return for a refund. I personally use the 6 3/4" on my GM truck and this is the antenna most of our customers opt for as it is a very durable antenna. If you're one who uses touch car washes, its guaranteed not to break.
Zach
TheAntennaSource
Edited by TheAntennaSource
  • 9 months later...
Sierra's have the regular antenna too. I have a 2020 AT4 that has the same regular antenna, the antenna "pings" my garage door going in and out of the garage, but no real issues.
My dad bought a 3/4 ton Denali diesel and it has the stubby antenna. Not sure if it's a Denali thing, a diesel thing, or a 2500 thing, or maybe just because it's about 6 months newer, or from a different dealership.
Doesn't really bother me anyways though, I usually listen to SXM anyways or sync my phone to the truck and listen to something that way.
Edited by 2020AT4
better wording
On 2/9/2019 at 1:02 PM, Donstar said:
My '86 GMC version of the Suburban had the antenna built into the windshield.  I remember at the time a push for GM to return to the traditional mast type antenna!  The reception is apparently superior with the exposed "coat hanger".  (Broken antenna's are often temporarily repaired with a metal coat hanger)   Another advantage is these antennas serve as an early warning device for low parking garages. ?
My first truck; '86 Chevy Custom Deluxe had the same antenna built into the windshield, also had the vent windows in front of the driver and passenger windows. Man I miss that truck, wish they would figure out how to incorporate those features on a modern machine...
I thought the same thing about the antenna , like really couldn't put this in the rear glass like other manufacturers? But then I also notice I dont listen to the radio anymore so I just took it off. Problem solved :^) for me anyways.
  • 4 months later...
LOL, was backing into my garage when I got the truck home last night, made sure the sharkfin clears, then clunk goes the antenna. Sigh, shorty ordered on Amazon.
GM used to put radio antenna's in the front glass.
As I recall, it was a common to improve radio reception by adding an external antenna.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 999 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
