On 2/9/2019 at 6:07 PM, gothp28 said:
Sent from my SM-G965U using Tapatalk
Had the exact problem... Shortened it down to a 21" from Antenna Source. Came with a required adapter, which increased the height another inch or two, but still did the job. :) https://www.theantennasource.com/CHEVROLET/SILVERADO PICKUP/Silverado 2014-2019.html
I removed my antenna and was planning to replace it with a stub, turns out, my reception is still perfect without it ??‍♂️
On 2/12/2019 at 12:31 PM, Eds240z06 said:
I first bought the bullet style because of looks & price but reception was horrible. I ended buying 1 of these. They have copper internals and now reception is great!
KEYO1E 4.8'' AM/FM Radio Stubby... https://www.amazon.com/dp/B07MJB9BY7?ref=ppx_pop_mob_ap_share
Are you satisfied with this antenna?  How is it compared to the stock as for reception?
Very satisfied!! Still getting all the stations FM & AM. I do live near a major city so that also helps with reception. But I also drive out to the valley a lot where it’s mostly farm land and im still able to get their local stations
lol you got me.  This morning while my USB stick was indexing after it lost its mind, I decided to try the FM button.  Haven't had my antenna attached for months now.
Nope!  No good here, but that was expected.
Edited by Daverado
On 2/10/2019 at 12:43 PM, Jmonty said:
Thanks for the tip, mine shorty is on order now
Installed with zero loss of reception, should get a better picture from the other side
  • Like 3
Got mine couldn't be happier.  Great reception.  Thanks for the link.
Edited by mafd2
Most truck's are shipped with out the antenna on ( antenna laying in the cab ) ,  Dealership cleans them up / take Photo's and then they add the antenna , then it ready to sell $$$$$$$
I don't like the look of the antenna either, but most of them serve a dual purpose. They let you know when your getting close to scraping your roof, or ripping off that xm shark fin.
    • www.enginelabs.com/news/what-i-learned-today-bearing-clearances-vs-oil-viscosities/
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
