On 2/12/2019 at 11:50 AM, O Town Denali said:
I never use AM/FM either.  Have taken off the antenna on last 4 trucks.  Cover with rubber cap.
where would one get a rubber cap like this ?
My '86 GMC version of the Suburban had the antenna built into the windshield.  I remember at the time a push for GM to return to the traditional mast type antenna!  The reception is apparently superior with the exposed "coat hanger".  (Broken antenna's are often temporarily repaired with a metal coat hanger)   Another advantage is these antennas serve as an early warning device for low parking garages. ;-)
I like the antenna for this very reason. If it touches the height pole going into the deck, then I know I know I'm not going to fit in the deck.
Since our 6 3/4" and 21" antenna products have been mentioned here, I will throw out there if you have any questions feel free to email or call with any you may have.
We stand behind our antenna products and if you're not happy with the option you went with we encourage to contact us to exchange to a different option or simply return for a refund. I personally use the 6 3/4" on my GM truck and this is the antenna most of our customers opt for as it is a very durable antenna. If you're one who uses touch car washes, its guaranteed not to break.
Zach
TheAntennaSource
Edited by TheAntennaSource
  • 9 months later...
Sierra's have the regular antenna too. I have a 2020 AT4 that has the same regular antenna, the antenna "pings" my garage door going in and out of the garage, but no real issues.
My dad bought a 3/4 ton Denali diesel and it has the stubby antenna. Not sure if it's a Denali thing, a diesel thing, or a 2500 thing, or maybe just because it's about 6 months newer, or from a different dealership.
Doesn't really bother me anyways though, I usually listen to SXM anyways or sync my phone to the truck and listen to something that way.
Edited by 2020AT4
better wording
On 2/9/2019 at 1:02 PM, Donstar said:
My '86 GMC version of the Suburban had the antenna built into the windshield.  I remember at the time a push for GM to return to the traditional mast type antenna!  The reception is apparently superior with the exposed "coat hanger".  (Broken antenna's are often temporarily repaired with a metal coat hanger)   Another advantage is these antennas serve as an early warning device for low parking garages. ?
My first truck; '86 Chevy Custom Deluxe had the same antenna built into the windshield, also had the vent windows in front of the driver and passenger windows. Man I miss that truck, wish they would figure out how to incorporate those features on a modern machine...
I thought the same thing about the antenna , like really couldn't put this in the rear glass like other manufacturers? But then I also notice I dont listen to the radio anymore so I just took it off. Problem solved :^) for me anyways.
  • 4 months later...
LOL, was backing into my garage when I got the truck home last night, made sure the sharkfin clears, then clunk goes the antenna. Sigh, shorty ordered on Amazon.
GM used to put radio antenna's in the front glass.
As I recall, it was a common to improve radio reception by adding an external antenna.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
