Just now, Sierra Dan said:
You mean this:
See the source image
YEP! I think this ^^^ is on its way. I think the ZR2 has shown that it can be done. I also realize they have to have some tricks up their sleeves when the model starts getting long in the tooth. Im thinking we have 3-4 years before we see this^^^.  Cant wait!
Options for Success Chris:
Buy a Sierra AT4 to get your 6.2   :gmc:
Buy a Silverado LTZ w/6.2 and Max Tow, then order a Trail Boss 2" Lift Kit ($1295)…... clean out the garage/stock the beer fridge and get to wrenching :thumbs:
Kit won’t work with NHT
Ryan B.
So will the kit bolt on or not bolt on to an LTZ with trailer/max (with the 3.42 gears) towing package, or is it just not recommended?
I don't see why it wouldn't bolt on. They are probably more concerned with the shock tuning and getting rid of the 2" rear high rake that's there down to a ~1" . All of your suspension components are the same in the rear except for the added block and shocks .
Sent from my ONEPLUS A6013 using Tapatalk
Supposedly the rear springs are “heavier duty” but I’m not sure what that entails. Beyond that it probably comes down to liability and diminished towing capacity making the original NHT ratings unsafe or inaccurate after install.
I would say for sure the warranty on the parts would be gone. Installing them on an NHT would give GM an easy “out” on that.
Anyone know what wheels those are ?
Speaking about the at4 you can get the 6.2 in a loaded lifted truck but no 342.
But at least it’s a 10 speed which 3:23 is equivalent to 8 speed and 3:73
Rough country has a kit that lifts the front 3" and 1.5" in the back. Only cost $700 and looks pretty simple to install. Way cheaper than the gm kit and actually levels the truck.
Edited by Ben Berkenpas
Ben , my dealer isn't crazy about using this kit....says top ball joint don't last...just sayin!     GH
That may be. I honestly know nothing about this lift. I do know that Rough Country lifts are usually on the cheaper end both in price and quality. But it may be an option for someone looking for a cosmetic look that doesn't really use it off road.
Yeah agreed. Nothing like being able to take your truck back to dealer for any and all issues. If you can swing more money do the gm kit which comes with eveytning
My LTZ with 6.2 is on order and will get the 2 inch lift at dealer, along with all the black parts.
The truck will still need a leveling kit? Because even trail boss trucks have a rack.
If it were me and my truck I would go aftermarket.
Less expensive and not as many components to install.
Then again the benefit of the GM kit would be that it should be covered by a warranty depending on installation.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,238 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
