16-18 paintable headlight bezels
HI all,
i know we've been told for years they they are not available without buying the whole headlight, but they are.
parts numbers are
23379004
23378968
i plan on ordering them in the next few weeks for my truck
58 minutes ago, jacobrmiller05 said:
HI all,
parts numbers are
23379004
23378968
Be interested to see if they are actually available, or if the part number is obsolete.
$113.25 each on GM parts direct or $299.99 for the pair on Ebay.  Simple math says Ebay is not always the way to go.
i agree, i'm buying a grille off a guy that works at a GM body shop and he pulled the part numbers for them. he said GM is pushing to sell complete housings instead of just the trim, but the trim is available, just can't find it in the normal parts catalog.
can't you just sand away the "Chrome" finish and paint your current ones whatever color you want? I understand being able to just swap them in a flash if you have the extras but I'm too cheap for that.
Pull the headlights out and just take the trim off to paint, and reinstall the lights for the time being.  Save yourself $230 and go buy something else for the truck!  :cool:
Most autoshops could turn something that small around in 1-2 days.. Take a vacation day or even uber to work and save the 200$!
  • 4 months later...
Hello guys I just wanted to confirm that you can get the bezels now, GM literally started making these as a single part number by themselves march 1st of this year, I work at a dealership and this is what it shows on the gm website
Got a part number for the bezels?
Sent from my SM-G955U using Tapatalk
parts numbers are
23379004
23378968
  • 3 weeks later...
  • 2 months later...
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
