Been waiting to sign up on this forum for a while now and share thoughts on this subject. We've had our 2023 High country 4x4 with has Adaptive Ride for a few weeks now yet really wanted to bring down the rear just a little bit to remove the rack.  What surprised me was how different our truck sat compared to every other 4x4 1500 chevy I've seen posted, not sure if its the high country suspension is different than others?  But there was only 1  1/16" difference if that from the front to the rear fenders to the ground.   I almost drilled another set of hole since I only wanted a 1/2" drop lol.  Lucking we end up with about a 1/2" rack.  Do love the way it looks now, wishing I could go lower both front and rear but thats not going to be easy with this adaptive ride crap lol.  Not sure how much this 1/2" lowering is really going to effects the adaptive ride or not time will tell or I wont even notice.
Regarding the whole shaking feeling most of us all seem to get when slowing down, yes its there.  Wondering if it is also the torque convertor at those speeds causing some of this.   Ours did it prior but it does seem a little more pronounced now (kind of livable IMHO just for the looks alone).  It happens at around 27-22 ish mph when deceleration.  I've attempted in different gears in L with different throttle / loads trying to understand how to drive around it or to create it more so.   One thing no one mentioned that also changed when we did these drop shackles is that there is now polly bushings versus rubber.  So if there was some shaking or vibration to begin with, it would only be even more pronounce now.  Also the connection point between the rear left spring and the new shackle is now farther away creating even more room for defection/vibrations.  Not saying any of this is truth, just food for thought that no one has mentioned.   Wondering if there was a drop shackle kit that had rubber bushings instead, that it might help eliminate some of that vibration we are feeling with these lower cost kits.  The concept of why it should be equal angles totally makes sense though, might have figure out how to shim it. Probably the best video explaining it.
Anyway, I don't have before but it wasn't much different about 1/2" higher in the rear.  This is the first set of holes not the furthest out ones. Same kit everyone else is purchasing on amazon lol.
Edited by Brad65ford
Thanks for the further insight. I have always notices the High Country trucks have the smallest amount of rake.
Can anyone suggest a YouTube how to on the shims? Or has anyone made a short video the are able to share?
What i haven't done is put in neutral  (not even sure you can with all these damn nannys on the truck) to see if it still does it and if its trans related.
Edit:
Its confirmed, putting into neutral removes the shacking.  Totally believe its in the trans doing it, just magnified when we do shackles.
Went for a 300 mile trip today, not to happy with the drop shackle mod.  Going to put the stocks back in there, the amount of shaking it does at that 30mph and lower is just to much.
Stock shackles are back on, the shake is still there by about 60 percent less.  Assuming stock angle sucks as they come out unless its the nature of the trans and the shackles exaggerating it.
Had the 2 degree shim installed today and it is back to factory smooth, if you want to call it that
Edited by passat774
  • 8 months later...
I had the Maxtrac 2" shackles installed on my 24 Sierra Denali yesterday and I slightly noticed the vibration/shudder on deceleration between 27-22mph, right now it's not bad enough to take them off as I like the leveled look better. Is this something that will get worse with mileage, my truck currently has 400 miles. The shop that did my install said they could do the rough country rubber bushing drop shackles but would have to figure out something to do on the adaptive ride sensor, that is the only reason for going with Maxtrac shackles as it came with a new adaptive ride bracket to keep warning lights off.thumbnail(1).thumb.jpg.c59d74f057d675308e8f81e149da50a8.jpg
I have a 2022 GMC Elevation and would like to install the 2" drop shackles as well. You still having the slight vibration?
Sorry for the late response but yes I do have a vibration on decel from 28-22mph. My brother has a truck just like mine that is not lowered in the rear and I can just slightly tell where his is but mine is extremely noticeable compared to his truck.
    • Looks like you have it figured out. Did you run a sensor into the rear diff housing?    What sort of diff temp swings would you see towing or not? I have wondered how hot it can get
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
