11 hours ago, smwoods91 said:
I’ll buy them off you. Are they the red AT4?
Yes they are the red factory tow hooks. They are not some crappy spray painted version. I took them off my truck when I installed a non-factory bumper. Here are a couple of photos.
I’ll take them. Can you shoot me a message?
Anyone else have some factory red ones to sell or trade?  Wouldn't mind replacing the black on my 21 silverado 2500 z71. Only have like 300 miles on my truck.  Shoot me a pm.
Just wanted to share that if you have the GMC with existing black hooks, you can reuse the hardware and just order 2 red hooks.  GM part 84338715.  I purchased 2 from eBay seller partscenterplus for $68 shipped.  They drop shipped from GM in a factory box and they bolted right up.
$32.28 each from GMPartsDirect
On 2/25/2021 at 5:47 PM, passat774 said:
If anyone has a black set sitting at home. I am interested in them
Do you need them for Silverado or Sierra?  I have a like-new set of black ones for Silverado.  Let me know.
Looking for Silverado, do you have the bolts as well?
This is for the Sierra owners, were you able to remove your tow hooks with the bumper still on the truck?   IDK if it's because I own a 3.0 liter and there is more stuff in the way, but the access to the drivers side bolts is minimal.  I don't even think the bolts would come out all the way without hitting a cooler.
I’ve got red.... ‘ 20Silverado trail boss with 10k miles
looking to trade for black in comparable condition
mine look new
Hello.
I did replace my tow hooks with the Rough Country ones in a 2021 Rst Duramax. Too much to type so...Watch this video and where the guy gets defeated by the bolt....you take a Saw Saw with a metal blade...cut that bolt that can't be taken out and then on re-install you just purchase a similar bolt and feed it from the other side.
It's a time consuming..knuckle busting job but it can be done.
Passenger side it's easy no cutting involved.
Good luck.
mine look new
I will trade you my black ones - 2021 Silverado Custom w/ 1000 miles.
Let me know!
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
