~2000 ppm of mg sulfonate  there's the secret sauce Grumpy in a straight cut of PAO with some ester component
golly molly BITOG cheapers get some testing with accurate FTIR, full KF water and GC for aromatics.  Al add pack, nope. Pipes and handling valves etc.
Took a run through BITOG recently, same wankers there lying about stuff.  Sad really. One of the staff members there a PhD poser bad mouthing founders of the site who did the science for hire by reputable companies.  I do note that HPL is a site sponsor now and most of the large oil supporters are gone now.  Thats a good thing if they had Grumpy Bear there holding them accountable.   🤔
Yea...:rollin:No! :crackup:
  • Haha 1
47 minutes ago, the wanderer said:
This is the VOA I got for the oil I'm running (premium plus pcmo):
Thanks wanderer. Boat load of additives. These cheaper clean reference samples make us want more.......and cost the buyer more over time.
Physical properties of Bklabs is wanting. We need 40C vis and VI calc,  FTIR, TAN, TBN, Karl Fischer water and OH bonds content and a baseline GC as diesel or gasoline reference to get some idea of aromatics content.
TR pentane insolubes = additive package before heating/activating in the engine.
Blackstone is a mystery to me. They provide both dynamic and absolute viscosities for the same temperature but do not provide any acid or base information. They use 'close enough for horseshoes' fuel and water. They do not provide data on oxidation, nitration, sulfation and so on.... Looks like you're getting what you pay for but...... Point of the VOA isn't just to find the additive concentrations but to provide an entire reference library for VOA/UOA shift.
On the plus side they do provide historical wear data for your motor type and provide the average OCI length for that data. Something other labs do not do. While many will find fault in this practice as it is not YOUR motors history, I find it provides a point of reference for 'normal' for the type.
Indeed, I agree. And you thought Red Line and MPT30K were additive rich :crackup:
Here is an HPL Euro (Supercar) 0W40 also missing key data but added Ox and N. @customboss do you recognize this lab by the paperwork?
Polaris labs based in Indianapolis but could be any of their contract services selling polaris under another name, Amsoil sends most of their customers  lab work there.
Bklabs charges extra for TAN TBN and any other testing they can provide. They have no FTIR capability.
@Grumpy Bear yeah isn't that SUS vis with cSt @100C interestingly a waste. Their viscometers are old school so they might be just taking SUS and converting it to share with customer.    Makes the customer believe they are getting two viscosities when its the exact same measure different standard!
The WIX Filters analysis is ALS labs work and dumbed down for consumers. They prefer to work only with businesses.
Edited by customboss
Add ALS labs
Well, isn't that interesting. Too lazy to measure density for an accurate cSt conversion from SUS. :crackup: They are just pulling it off a chart then and assuming a density of 1.00. :nonod:
  • Sad 1
Why they are proud to be the  " McDonalds "  of oil analysis....... quote from founder their father.
  • Sad 1
My daughter's boyfriend (19 y/o) bought his first brand new truck this past Saturday. He bought a 2022 Custom with the 2.7. It had 300 miles on it when he purchased it. Today it has 570 miles on it and the CEL is on. He has not made it to the dealer yet to have it looked at. Does anyone here have any ideas of what could possibly trigger a CEL this early on? Any known issues on a brand new 2.7 that is known about here? I researched this engine before he bought it and even went and talked to a Chevrolet service manager that is a close friend of mine just to make sure it was a good buy. I couldn't come up with anything negative about it. Now he has a CEL on a brand new truck and I am feeling bad about it. Just seeing if anyone has any ideas here on the forum.
  • Haha 1
Maybe the evap. Pretty common on the 2.7. It’s a quick fix.
Thanks for the reply. He stopped by an auto parts store just a bit ago. They read code P2DE7.
38 minutes ago, Flatus said:
For some reason , some douche named Amcguy1970 finds humor in this.
Pretty sure he's laughing with you, not at you. 😉
There wasn't any  laughing or reference to any humor in my post.
    • I am new to this… but I saw some of your replies to another person doing the same as me… trying to replace the temp control actuator in my 05 GMC SIERRA, And can NOT get to it… how do I get the center console panels off, do I have to take ALL of them off to get to it? 80481681120__F97CE005-C5E5-4FBF-9589-1388214E3586.MOV
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
