8 hours ago, joshuapchase said:
Thanks for the information... I found a set and swapped them out! Look great and after selling my takeoffs only cost $200... winning!
Awesome to hear!  Glad it worked out for you.  It looks great!
On 5/9/2019 at 7:45 PM, Aldiaz1551 said:
Put some 295/70r18. No rubbing no trimming and looks good.
Looks good.  I have the same truck.  Any speedo change?  Any way to correct the speedo or are you/most people just not worried about it?  Did you have the duratrac before, are these quieter?
I ordered the hypertech Speedometer Calibrators Inline - Part #730129 after installed my 35's...speedo was off by quite a bit at higher speeds and with a new truck i wanted it spot on. The calibrator was very easy to program and install and after checking with two difference GPS devices and a radar it is now spot on. Highly recommended.
  • 4 months later...
For those who upgraded to the 287/70/18 Ridge Grapplers, which are an E load 10ply, did the ride quality go to crap? I am worried about too stiff of a tire and an unruly ride in day to day on road driving.
  • 4 months later...
  • 5 months later...
Hey, I’m thinking about adding bigger tires to my AT4. I don’t want to add the 4inch rough country lift. Can you add or send me pics of the tires from the front side? I’m wondering if they stick out at all and how much. I have the same color AT4. Same wheels. Need your help bud.
Got rid of oem tires immediately so my only point of comparison is my 14 denali with a level, 20” wheels and tires just shy of 35”.  My AT4 rides a lot better than my old truck.  I like the bigger sidewall that comes with an 18” wheel.  I really can’t compare to factory though
  • 3 months later...
I didn't go with the "biggest" that would fit but here are 275/70R18 Milestar Patagonias.
-Eli
i'll probably do 285/70r18s on my AT4 with +1 offset Fuel Anza wheels.
I had full 35x12.50 on my F150 and the hit to ride quality and fuel as well was more than expected. i'm hoping a 34x 11.5" tire won't hit me too hard.
I can't find any tire larger than stock that's not 10 ply. largest i seen was 265/70 which is only 1/2" taller
If anyone on here has a 265/70r18 did you notice the tire being taller?
-Eli
Looks good, i have the same size on my Ram. No rubbing at all?
not even close.
I got my truck last year with the 20" rims, so I was kinda curious about this for the 20" factory rims.
Has anyone ever looked into WildPeak tires? Its what they started putting on the 2WD work trucks where I work. I guess they work great in snow & mud even for just 2WD. I asked one guy if he just got new tires put on his truck and he told me "yeah last year." Sounds like they last a long time. Anyone have any experience with that brand before? So far it's kind of the way I'm leaning when my factory tires are wore out. Anyone know of the biggest size of tires for the 20's?
I've never used those tires but I hear people like them.
For sizes, I just put 295/60R20 Cooper Discoverer STT Pro tires on my AT4 and they fit with "no" rubbing. I say "no" because I did manage to get them to very, very slightly hit the mud flap bracket on a hard right turn into a steep uphill parking lot, so a mud flap removal may be necessary depending on where you drive.
I originally wanted to do 285/65R20 but wasn't able to get the tire I wanted in that size, and I briefly considered the 295/65R20 which are just a hair over 35" tall but decided it wasn't worth the hassle if they rubbed.
I do have a 1" level on the front but the tires would have fit without it, it's only there to maintain pretty close to factory rake with the RAS springs picking the back up a little bit.
I like it! Same color as mine too, only difference is I got the 6-1/2' box. I don't want to put the 1" leveler on mine...my brother did that with his old All Terrain & I thought it made it tougher to see the nose of the truck. I have a hard enough time seeing the front end the way it is with the shorter hood style (I had to put a 1-3/4" lift kit under the seats so I could see front end better). I don't really do much off-road driving (not counting gravel roads), the little I do isn't like extreme rock climbing or anything (construction sites and farm land). But we do get a pretty good amount of snow here though, so I don't know if that makes a difference or not with snow build up. How were you able to figure out which ones you could use without having them rub?
Edited by 2020AT4
    LCH14
    LCH14
  • Who's Online   6 Members, 0 Anonymous, 985 Guests (See full list)
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
    • Your truck lowered, looks good. I'm happy with the stance on this. I may need the extra ground clearance given my location/situation.
