On 5/8/2019 at 10:01 AM, cccjrsbox said:
A better video below.  Figured youtube is better than the file above...
 https://youtu.be/j68egCpZm_w
Sounds great! Did they weld or clamp in the the pipe? I'm assuming the muffler delete caused the check engine light to come on?
On 5/8/2019 at 2:49 PM, Silverado4x4 said:
Sounds good on the start up but I would think its going to make a popping and cracking sound when letting off the throttle going down the road which is going to sound like crap.
No thats a bonus.
Welded.  No check engine light, been running just fine since March 2019, only $50 bucks to boot-
Awesome, thanks for the info! Did you cover/remove the resonator screens? Any drone or issues at high speed (75 mph?)
Sorry for all the questions, I want to do a delete on my truck next week, so I think.
I'm not sure if there was ever a flapper valve, but there's not one there now.  I covered the screens a few weeks later, probably a 15% additional increase in sound - worth it.  I can notice a bit now when the engine kicks down to 6 or 4 cylinders - sounds like a Harley - but since this only happens when coasting, no big deal (I live in a mountainous area - always going up or down hill).  As far as drone - quiet at speed, louder under load.  Some back crackle when decelerating between 20 and 10mph (but I like the crackle).  Have had trucks with aftermarket mufflers in the past with more drone.
Perfect! I have the AFM disabler so I shouldn't have any issues with any real loud popping (I hope). I think I'll leave the screens uncovered at first and see how that sounds, then go from there. Thanks again for the info, gave me some reassurance.
Had the muffler and flapper removed on my 2020 Custom Trail Boss. Love the sound!
I did not do a delete of the muffler but I upgraded to the Cat-Back after I bought it.
Why delete it? Is it "just" for sound or is there any other reason?
? Every time I hear someone say no drone and they have a loud exhaust or chop something off. I have been around cars and the performance world long enough to know that is suspect...
Tyler
Tyler
Which is why I recorded a video from inside the cab of my truck as I drove down the road.  ?
My 2018 that is straight piped and resonator removed, absolutely has a drone.  I don't care, but it's there.
The 2019 really doesn't. Not sure why... maybe because there are two pipes rather than one... maybe because they exit out the back bumper rather than out the side... perhaps the cab is much better insulated from outside noise...  Maybe a combination of all 3...  I don't know, I am not an acoustic engineer... but I am driving the truck and recorded a video for the nay-sayers, so it is what it is...
Taping up the screens will give a slight drone.  My advice is to ditch the muffler and flapper, but leave the resonance screens alone, best of both worlds.  Loud when you stomp on it, fairly quiet when you just cruise along...
    btm
    btm
  • Who's Online   6 Members, 1 Anonymous, 1,558 Guests (See full list)
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
