On 5/8/2019 at 10:01 AM, cccjrsbox said:
A better video below.  Figured youtube is better than the file above...
 https://youtu.be/j68egCpZm_w
Sounds great! Did they weld or clamp in the the pipe? I'm assuming the muffler delete caused the check engine light to come on?
On 5/8/2019 at 2:49 PM, Silverado4x4 said:
Sounds good on the start up but I would think its going to make a popping and cracking sound when letting off the throttle going down the road which is going to sound like crap.
No thats a bonus.
Welded.  No check engine light, been running just fine since March 2019, only $50 bucks to boot-
Awesome, thanks for the info! Did you cover/remove the resonator screens? Any drone or issues at high speed (75 mph?)
Sorry for all the questions, I want to do a delete on my truck next week, so I think.
I'm not sure if there was ever a flapper valve, but there's not one there now.  I covered the screens a few weeks later, probably a 15% additional increase in sound - worth it.  I can notice a bit now when the engine kicks down to 6 or 4 cylinders - sounds like a Harley - but since this only happens when coasting, no big deal (I live in a mountainous area - always going up or down hill).  As far as drone - quiet at speed, louder under load.  Some back crackle when decelerating between 20 and 10mph (but I like the crackle).  Have had trucks with aftermarket mufflers in the past with more drone.
Perfect! I have the AFM disabler so I shouldn't have any issues with any real loud popping (I hope). I think I'll leave the screens uncovered at first and see how that sounds, then go from there. Thanks again for the info, gave me some reassurance.
Had the muffler and flapper removed on my 2020 Custom Trail Boss. Love the sound!
I did not do a delete of the muffler but I upgraded to the Cat-Back after I bought it.
Why delete it? Is it "just" for sound or is there any other reason?
? Every time I hear someone say no drone and they have a loud exhaust or chop something off. I have been around cars and the performance world long enough to know that is suspect...
Tyler
Tyler
Which is why I recorded a video from inside the cab of my truck as I drove down the road.  ?
My 2018 that is straight piped and resonator removed, absolutely has a drone.  I don't care, but it's there.
The 2019 really doesn't. Not sure why... maybe because there are two pipes rather than one... maybe because they exit out the back bumper rather than out the side... perhaps the cab is much better insulated from outside noise...  Maybe a combination of all 3...  I don't know, I am not an acoustic engineer... but I am driving the truck and recorded a video for the nay-sayers, so it is what it is...
Taping up the screens will give a slight drone.  My advice is to ditch the muffler and flapper, but leave the resonance screens alone, best of both worlds.  Loud when you stomp on it, fairly quiet when you just cruise along...
    C. Hart
    C. Hart
  • Who's Online   3 Members, 0 Anonymous, 525 Guests (See full list)
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
