Has anyone on here debadged their multipro tailgate? I'm picking up my AT4 tomorrow and thinking of doing this. Any pics?
Sent from my Pixel 3 XL using Tapatalk
I took off the Sierra and at4 from my tailgate and just left the GMC. I was going to replace the GMC with a large at4 badge but I think it looks good the way it is now. Not so busy556925f5e4f44d0026f27c027d706f46.jpg
Sent from my SM-G975U1 using Tapatalk
This cleans it up. That tailgate is so busy from the factory. There is a white one i see that is debadged in my town.
I completely agree.
I just partially debadged mine this weekend, and added matte black vinyl inserts from TVD Vinyl Decals to the remaining chrome lettering. Completely changed the look, IMHO. Also, the “GMC” was not installed level at the factory. Every time I looked at it, it bothered me...
At some point I'll remove the big center "Sierra" as I believe it's just too much in the middle...I actually purchased from the dealer the smaller "Sierra" from the T1 Denali and plan on putting that in the lower left and keeping the SLT in the lower right...i guess similar to the K2 tailgate layout. Just more symmetrical to me. Did yall use the eraser wheel, or floss method?
I used some braided fly line backing to get the letters started, then slowly peeled them off. I removed the residue from the foam adhesive tape with WD40, Windex, and the edge of a credit card.
I rode around for about 3 weeks with all the emblems off... Just seemed too bare, so got the black GMC emblem reapplied. I think it looks cleaner now. 7be048d83006d2997f042be9755585ea.jpgea1b8d54c0310a8dd77a4102e03e0e24.jpg
Sent from my Pixel 4 XL using Tapatalk
Had the "Sierra" badge and the dealer logo removed before it was polished and the ceramic coating on the paint, no more Sierra on the truck, people ask what a AT4 is.
On 5/5/2019 at 9:34 PM, DeLucecc said:
I did mine when I first got it. I think it looks a lot better.
I did this, but kept the Denali emblem but in black.  My truck is black so it blends in, but adds a little something to the back.
    • In their own words:    https://blog.amsoil.com/how-engine-sludge-forms-and-how-to-prevent-it-2/   [Quote] Synthetic Oil Helps Prevent Sludge Fortunately, sludge and varnish deposits are something that can be controlled. Using thermally stable synthetic base oils reduces the rate of degradation (oxidation).   Antioxidant additives further help reduce the rate of degradation. One of the most widely used is zinc dithiophosphate. Not only is it an excellent oxidation inhibitor, but it is also an outstanding anti-wear additive.   High-Quality Additives Fight Sludge Fortunately, it is possible to address many of the issues that occur after the initial oxidation stage. Additives, such as detergents and dispersants, help promote the suspension of contaminants within the oil and keep them from agglomerating.   Detergents, which are also alkaline in nature, assist in neutralizing acids generated in the sludge-building process. Antioxidant, dispersant and detergent additives are consumed during use.   To achieve maximum life expectancy, use a motor oil with high concentrations of antioxidant, dispersant and detergent additives.  [End Quote]   So quality base oil and then the last sentence above. TBN and ZDP levels matter. The one thing not covered was sufficient viscosity. Sad.     And yet we now have since API SN lower amount of them all with the only real change being a slight up tick in base oil selection. Along with lower concentrations of everything that makes oil work and lower and lower viscosity there is still an insistence on longer OCI's.    How low does the peanut butter and jelly level have to get before we say it's just white bread folded?    The new smoke and mirror treatment is the 'additives are INVISIBLE' to UOA testing with a health dose of TRUST ME.    I'm not picking on AMSOIL. This is coming from all of them. Every last one of them that abandon the low wear model in favor of the high mpg/EPA compliance model.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
