IF GM pulls up short on you, it might be time to seek a quality independent body shop. They deal with these issues daily....
I looked at mine again on lunch. Its hard to tell but it seems like it might sit a bit more to the drivers side but its hardly noticeable. I think the new body lines make it worse if the bed is a bit off. Due to high volume manufacturing I'm sure every truck bed is off in some sort of way.
I gaurantee it. Get some one that says their truck is perfect, then get someone that has OCD, or is a quality inspector, and I gaurantee they'll find something wrong.
Mine is off a little bit, but I can live with it.   Who knows what can of worms would be opened if I fool with it.   My last car was a Corvette and that had a few misaligned panels and it was a headache to get it corrected, and it never got 100%.
So true.  Let the dealer mess with it, and more than likely something else will be off, or you'll come out of the deal with a ding/scratch.
Edited by Bftx
Is in OP defense if the bed is way off I would want it fixed. I'm sure 99% of trucks on the road have beds that are slightly off  but if its way out of wack GM should correct it
Went back and got my truck unfixed while GM decides what they want to do. Couldn’t be without it another day!!! Actually, I only went and got it because my loaner was a ****ing WT package.
driver side sticks out approx 1/4” from flush with the cab. Passenger side is tucked behind the cab 3/4” from flush. Apparently they’re supposed to ride 1/2” inside from cab on both sides.
still no response from GM. Service rep said GM could easily say it is a non-fix Problem and I’ll be stuck with it. Not what I wanted to hear.
The new norm in the auto industry......
Prices continue to escalate while quality continues to decline.
Happens with just about every manufacturer. It pays to buy that extended warranty now more than ever.
UPDATE!!!
Truck went in for first service and “Jingle jangle on the driver CV shaft” just to get it on record. Tech let’s me know a solution may be in for the offset bed...
Says the cab is adjustable and will need to be shifted to center the bed. Not sure how this will affect the front clip line up.
Well, that fell through. As of now, no adjustments on cab or bed. Tech said he walked the lot and found 2 trucks that had perfectly centered beds. Says the rest are off by some amount. The loaner I’m in while they looked at mine again is off the same amount or more than mine and to the opposite side. Seems their engineers are putting their heads together for a fix. But, no TSB as of yet.
How about your Jingle issue as stated by others in another thread? '
Did the dealer come up with a fix for that?
Negative. They “can’t hear it”. I showed them the TSP for the problem. Confirmed I have the AAM built front axle and he said he’d make the annotations
Edited by Chambo
  • 3 months later...
Same.  2019 LTZ, day 2 I’m driving on an open road, I glance in my driver side view mirror & thought the back door wasn’t shut because the body line was off.  So I pulled over to check, and it was shut.  This is when I realized it was misaligned. The body line has a 1” jog between the cab and bed on driver side. When I checked the passenger side, it’s aligned perfect.  Confusing how one side is aligned but the other is way off.  Returned it to the dealer who sent it to their body shop.  I told them to get me a new truck and that a $56k truck should not be seriously misaligned like this.  So looks like I’m losing my beautiful blue and getting a shadow gray instead.
I brought mine in because was getting paint chips on the bottom of the box in front of the rear wheels and front edge of box after a whopping 511 miles, about 40 miles on gravel. Service looked at it and noticed the box was misaligned. They said they would look into a fix and call back. Hope something has been figured out by now.
    • No, not yet. Hoping I'll have something a little more definitive in the next day or 2. They seemed to be very confident they can order it. I do have some understanding of the whole allocations and restraints stuff so we'll see.   I think this is what I'm looking for.   3000 ORDER ACCEPTED BY PRODUCTION CONTROL
    • Then you haven't read your book. It also says check every 400 miles.   If you need to add multiple quarts in that distance then reading the stick isn't the issue. Put the two together and it will make sense. Read it all.
    • Following up on my topic, I put an O2 sensor in it which seems to have got rid of all the b2s1 codes (I ended up having multiple codes). Next I’ll try to figure out the P0011 but I might focus on exhaust manifolds first, they’re getting pretty rusty. I’m hoping this thread will help someone in the future.
    • I’m going off the instructions.
    • My expectations are a bit higher.    No faded paint or dry rotted plastic/rubber. I use a dressing and a ceramic sealant. No hazy headlights.  No door dings. Small dent in the front bumper. All rock chips repaired. No brush scratches. No windshield chips. No fender benders. Limit damage due to a proactive plan the included ceramics and PPF and prompt attention to any exterior issue. NO RUST. Stays out of the salt and had the rear wheel wells Line-X coated as well as the bed which has a bed rubber and has been under cover since before I bought it. Washed and detailed regularly. Rex chewed up the tow button, got whacked and the button replaced the same week. He's leaned his lesson. If I can train a dog the kids are easier.    All suspension is original save the King Shocks I installed very early on. 50 years ago dad told me a good shock will keep the screws in the dash tight and the front end mint. He was right. Everything within new spec yet, tight and aligned well several times. Coolant system is OEM save the modifications I made early on. Not a single leak anywhere on this machine. (Did repair an intake leak on #4 during the HPFP replacement.) The injectors I replaced didn't need to be. They checked out great. One of those, while I'm in there with the manifold off and the fuel rail apart things.  Not a stain or abrasion one to the upholstery. Have kept is covered since new. Never had a carpet, it's a work truck but the carpet squared I laid on the floor have keep the factory rubber liner MINT. Ceramic wind tint helps preserve the interior.    Original BRAKES with 60%+ left of the pads and rotors mic excellent. We just did a full preventative brake service. Disassembly, clean inspect including measurements, lube, Dot 4 power flush including ABS system.    OEM battery. OEM vacuum pump. In fact the only things not OEM are a pinion seal the high side pump and injectors and a small plastic shield around the starter. All hoses/belts etc.. are still in service and doing well. Original tires lasted 125K and had I known some additional details would have made it to 150K with legal tread. (Date out is six years, not 5 and Continental says they are good for 10 so I pulled the trigger to early)   I never let my children or grandchildren run the show. Feet on the floor and hands in your lap. Dog gets a pass.    A truck is a machine the gives you back whatever your willing to put into it. Same as a computer or a butter knife. I use a shovel but I scrap it, hose it off and oil it when I'm done with it. My original spade I've had 60 years.      Set the bar higher...you spend less money. No, before you ask, I have spent a fraction of the cost of a new truck in my entire maintenance program including disposables, filters/fluids etc.
