Hey  everyone  it's time to get real with gm, I'm looking for people that want in on this upcoming class action lawsuit. I have a 2015 Sierra that have the tapping/knocking noise. I discussed with gmc, they played me off. The dealer did a #7 injector & lifter Replacement job, that they screwed up. But I got that A$$ Now. I don't trust gm or the dealership. But, if your vehicle has that noise, then you need to inbox me at [email protected]
  • Replies 38
Is it good a$$? Big butt or meh? Lmao!
Hope You get your truck fixed. Shouldn't matter if its outta warranty if they did the work. You just have to prove they caused the failure.
Sent from my LG-G710 using Tapatalk
I didn’t quite get this. Class action lawsuit for what noise? Lifter tick? Vacuum pump tick? How were you played off if they did the fix?
Hahaha, good laugh for the morning...good luck with all that...
Is this a late April fools??? ?
Class action lawsuit for the tick? That’s a good one ?
Let’s see so far mine has had a recall for the airbag, seatbelt, & power steering. Now a “extended warranty” on the vacuum pump because possible loss of power assist to the brakes. I think most of us have bigger fish to fry than a injection pump noise. ?
Let me guess your lawyer will get 33 & a 1/3% of any and all settlements... ?
3 hours ago, lapoolboy said:
"You got that A$$ now" ??? ?
2015 is probably out of warranty by now? You're wasting your time.
Yes, that's right . Too bad you not a believer!
If, by some miracle you get class action status and win, let me know how that check from $16 works out for you lol
No, it's not April Fools, But Human Fools. That's why they getaway with stuff. Because of do nothing people like you. But we winning.
I Got Paper. But It Will Get A 6pack. Plus this not even about money, But You Wouldn't know about that. Ignorance by ignorant people equals 0. Have a great day.
Hahaha, you're so pretentious...If it is not about money, what is it about? sticking it to the man? Lol...I am having a wonderful day and will continue to do so and I and others laugh at your foolhardiness on here.
People Understand that the lifter noise is actually  a combination of the Active Fuel Mgmt. System and the Valve lifters Rail Train. A defect in those 2 systems is the culprit. GM know it and the dealers know it. All you need is do your research. This problem is exclusive to the 5.3 engine. Gm been knowing since 2000, but no one has held them ACCOUNTABLE. They WILL Play you off. If you let them. The Vacumm pump is junk also, mine been replaced 3 times. Point is, people just Continue to get rammed up the hole and Don't try to do anything about it. I'm moving forward.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
