Hey Folks,
I'm still hung up on my final decision from upgrading from my 2017 All Terrain to a '19 AT4 or Denali. However, I believe I am 5'11 and feel really small next to a AT4. Is it because of my height or just because that new factory lift really makes a difference? For those that moved up from 2017 or similar Sierra to a AT4 have you had any weird height difference feelings about the truck? I'd like to know because standing next to one on the front lawn of my dealership I felt really small next to it. Thanks.
I went from a 2017 HC to the 19 AT4, I'm 5'9" and without the tailgate down, there is no way I can reach anything in the box from outside when standing in the ground.  The new trucks are definitely taller.  I love the extra height when driving around, able to see the roofs of most other vehicles.
Well the AT4 stock height is about 5 inches taller than the stock height of the old trucks sooooo...
Sent from my Pixel 2 XL using Tapatalk
Jesus. Didn't know it was that much. Time to whip out the ol'measuring tape to see if it would fit in the garage.
Edit 2019 AT4: 78.4 inch in height | 2017 73.8 inch in height. Holy flamingo.
Edited by FknLeon
I'm 5'11 as well, but I'm also 265lbs and pretty broad shouldered.
My previous rig was a 5th Gen 4Runner and I felt too big for it at times.
Yeah, this is why I went with an RST and not an AT4 or TB. They AT4/TBs were just too big for me when I stood next to them. I'm 5'11", too, and coming from my 2007 LT CC, those lifted trucks just felt huge.
I think the AT4 hides it better, though, especially with the 20" wheel package. It doesn't look as "high" as the TB does from afar.
Also, I have an older garage, and the shark fin on my '19 RST with 20"s just barely fits in... so a TB/AT4 would have been left outside in the DFW hailstorms this spring, which I didn't want to suffer through.
Yah these trucks are pretty tall, the floor height is tall as well. I dont have running boards and my TB floor is about the same height my 99 with a 6" lift and 35s was.
Sent from my ONEPLUS A6013 using Tapatalk
BTW the rim size has nothing to do with the overall height on these trucks. There overall diameter of the tires are the same for the 18" and the 20" wheels. It's purely cosmetic...
Current height of my AT4 to the top of my shark fin is 84.5" I don't fit in any garage under 7'6" (I don't risk it anyways)
Maybe it's my napoleon complex but I'm 5'6" 180# and I traded in an '18 Toyota Tacoma and I always felt cramped73cf9332035cb23b62a3974d20ae30b3.jpg
Sent from my SM-G975U1 using Tapatalk
8 hours ago, FknLeon said:
Hey Folks,
I'm the same height as you and I can't even get into a stock K2 without running boards. I can't imagine clambering into an AT4 every day, even with assist steps.
Those Tacomas are cramped. Less interior space than my compact car.
Good reason to get side bars so I could climb in. I just tried it without, forget it. I'm 5' 10" and it is much taller. I'm getting much older too!
Here's a different point of view. I'm 6'3" 260 and 65 yrs young. I came from an F150 Lariat. Had to bend my head to get in the door.
The AT4 is a perfect fit for me. At 5'11, I don't think you'll have a problem especially with side steps. It is a bit of a drop when you get out. My other half almost fell the first time she got out.
I'm 5'9 - The truck is big but there is something about it. Outside of a heavily lifted truck  or semis you are the tallest thing on the road.  The multi-pro tailgate makes all of the height/bed issues go away....
It really is a fantastic truck..
I'm big on keeping my truck in the garage. With the new AT4 height I'm pretty sure it would hit the pull / support arm of the garage door as it goes into the garage. I believe however that a SLT or Denali could fit.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 557 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
