6.2 Lifter Replacement Victim 14,000 miles
smokytrail
Beating a dead horse here...
Have a Denali 6.2 that I just purchased from CarMax (with an extended warranty/Thank God!)
Tapping sound from the start.
Ran two tanks of 91 octane to eliminate possible octane knock.
Took me past the 7 day return policy and 30 day standard warranty with CarMax.  Didn't really bother me because of the factory warranty.
Truck looked brand new. Even had the wrapping on the DVD player.
Popped the hood and started looking for an exhaust leak.  I found a donut/flange laying on the crossmember.
Took it to the dealership.  Found that the truck had two new fuel injectors and a new Catalytic Converter.  Someone was searching for the cause of the sound.
Dealership tightened some gaskets and said the truck was good to go.
It made the deafening tapping noise on the way home.
I returned the truck to the dealership.  Even though I have purchased 4 vehicles from them in the past to include a current 2019 Arcadia -- they had no loaner for me.
They kept the vehicle for two more days.  Could not find the cause of the noise.
I went back to speak with the service manager.  He was not happy.
He went on a ride with me and heard the noise.  Claimed it was the transmission searching for the proper gear.
Weird because the noise happens constantly -- to include start up and idle.
Told me his 6.2 made same noises and it was normal.
Finally took it back to CarMax.  They sent it back to same dealer with a promise to pay for diagnostics.
Miraculously, dealer finds lifters to be the issue.
I'll keep updated on status of cam, etc.
I think I'll trade this lemon in on a diesel or anything without AFM.
Will also not be purchasing from Bob Howard GMC in Oklahoma City.
if it's still under warranty LEMON law it  i would not accept a  "Friday afternoon car" or "Monday morning car"  your wasting your time  with a lemon that will have more issues done the road..  that is why they took it to carmax because they buy any garbage cars
DONT trade it in   it needs to be Branded a lemon..
looks like the probably never change the oil (in like 13k miles )or used the wrong one or not enough
you will actually get more money if you lemon law it
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
