Repair Active Fuel management for just a few pennies DIY fix.
This is not DIY in Oregon or New Jersey ..    haha  :rollin:
GAS QUALITY effects on how your  AFM works
garbage GAS  fudges up the ECM  and it will rapidly shift between v4 and v8 mode causing damage to the system...or excessive wear and tear...
if you all ready have "excessive wear and tear"  it's too late...
Also your transmission will be searching for gears less often as well using 91/93 oct..
you get to stay in a higher gear longer
i have tested varies gas station brands and octanes as well.. i have came to the conclusion that these two BRANDS of fuel WORK the BEST!!  on AFM engines..
Chevron/Texaco/CalTex
91 or 93 Octane
 and
Mobil/Exxon
91 or 93 Octane
WILL work the BEST with the AFM system  both brands are tied #1 spot for a fully functional AFM system..
brands that cause the excessive  rapid shifting or dysfunctional/ non-functional AFM system include
using 91oct
Shell
Arco/BP
Marathon/USA gas
[Insert Name of your Cheap Gas Station Here]
Interesting you say that. I did away with AFM using the Range device.. Let me tell you the truck is more responsive, but back to this topic. I just filled up with BJ's gas (87)and it runs like crap.  Exxon made it run smoother on 87. I will try 91 Exxon after I run through the crap I have in there.
Between my '14, '15 and '18, I've run Mobil, Shell, Kwik Trip, Casey's BP and probably more. All 87 octane. All three trucks ran/run perfectly.
The Costco 91 octane has done will thus far.  It is Top tier as well.
The DI motors seem less influenced by lower quality fuels.  Besides, the L83 makes a lot more horsepower per cylinder compared with the Gen IV 5.3s and so can run in AFM mode about 50% of the time whereas the older generation was about 10%.  4-5 horsepower per cylinder difference is a lot.  Even more torque.
Techron Gas is gold.. I use it in dirtbikes, cause the additives in the fuel last forever. I can fill up a bike tank with 91 Techron, 6-7 months later its still good and clear, not oxidized or yellowing into shellac. TEchron #1!!!
Yes.  Techron is some of the best fuel system cleaner additives out there.
the proof is in the gas mileage  I wanted a SUV but also wanted good MPG ,  hitting over 28.9MPG with the 6.0L (W/Hybrid Module) ...
 AFM works all the way upto 1900RPM or 80MPH  that is how I get the good MPG. with the good fuel  and octane..
Small cars are pretty useless where i live  since our speed limits are very high and if you get hit at 45 -60MPH your dead in a car.. or hurt pretty bad aka: a vegetable.  I have seen some pretty nasty crashes  like a 1996 tahoe hit a  1994 honda accord  the people in the accord got ejected.(dead).  they were hit at 55MPH.. T-Boned  they did lower the speed limit to 45mph  afterwards  but tooo late
also btw the tahoe just need a new front clip and it was ready to hit the road again
octane definatly improves mpg, on our truck I've found no gain after 89 octane, no mpg improvements with 91 octane .  87 is horrible milage 12mpg
Mfg set tuning curves per usage, buyer, intent. So, staying at the peak of the curve (ie 87-89) allows for max mpg.
But when you get away from the peak, things can get iffy and requires manual adjustments or parts upgrade.
On my Cadillacs, we ran a number of long term tests at various octanes with and without simple adjustments (ie timing). But in the end, the best $/mile was the spec of mfg. (Ie spec at 91, but 89 or 87 would have a mpg drop that cost more than the savings on price per gallon.
You have not had any injector problems? That's the only issue we ever see with 14- 19 trucks. It's not the fuel you use, but the placement of the injector.
No injector issues. Been retired for a year now but saw more issues with 6.2 injectors for some reason. My  trucks were all 5.3's.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
    • What’s missing in all this is patience and investment in the future. Buy a 170K starter home. Ten years later sell it invest in a more expensive home. Eventually you’ll have a 600K home and pay starter home payments. Buy a starter car. Maintain it well. Save the payments after it’s payed for then buy an expensive car if you desire. Buy a tumbler make your own coffee, pack your lunch. Cook your own dinner. Most importantly take care of your car.
    • People mislead themselves. Statistics are highly useful indicators.   Here's the tie-in to this thread. If an oil sample tests shows a wear indicator of 7 using cheaper ACDelco oil, and a wear indicator of 2 (lower = less wear) using a particular brand of Mobil oil, and wear has a linear relationship with engine lifespan, anyone could assume that Mobil is reducing wear by more than 50% (let's just say a 200% reduction for you red state people trying hard to do math) which leads to increasing engine life by 2x. Perhaps, in a vacuum, by itself, when dreamed by AI.   Yeah?! That's what the statistic is saying, isn't it?   No, it isn't. It didn't come out and say engine life is doubled. That's a very bad assumption, and a case of severe myopia by assuming something potentially untrue about the only data point in focus.   Average cost of a new car is 50k. You bet it is.   The median cost of a new car is more like 35k. Expensive cars are skewing the perception that "average" now means a $50k price of entry for a very average automobile. And that's not true. People who don't understand statistics twist the living heck out of them to mean all sorts of things they don't actually mean.   "Average" new car payment is $1000/month. Yep, it is. And in that number are all the $35k new car buyers who bring significant equity, and the $25k new car buyers who finance the car for a month just to get a rebate, and then pay it off. Know what isn't in that number? All the payments made by people who don't finance a car.   Picking one's own data point (don't have a car payment, never paid $50k for a new vehicle, my house cost $170k, I afforded a middle class lifestyle on $4.50/hr) is just a data point. Just like earning $25/hr in an area where the median home price is almost $1 Million is a data point. In fact, it's a lot of data points given that 80% of the US population lives in/around major cities. They're not idiots; the vast majority of them do it to make a living because that's where the big money is.   The highs have become higher, lows have become lower, and how your personal mileage varies is not truth for an entire country. At the same time you can't NOT acknowledge the data. While it doesn't paint YOUR personal picture, it certainly tints the reality that you also live in, as does your single data point.
