Does anyone have any phone mounting options that's working out real well for them?
Right now I have an iOttie mount, that overall works pretty good as far as holding the phone right where I need it, but can't get it to stay stuck to my dash in hot weather.  The rubber adhesive pad it suctions onto keeps coming off.  Hoping to find some better solutions.
I just got this one:
https://www.amazon.com/gp/product/B07NPS6S41/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
So far so good.  It grips the cup holder pretty good and puts it right where I need it.  This was bought for my wife’s Equinox, but I think it would work well in the truck if you’re willing to give up a cup holder.  There are ones with longer flex tubes so give some thought to how long you want it to be.  I looked at the Weather Tech, but it was too expensive for what it is.
13 minutes ago, rmkmb said:
Definitely wouldn't get one that goes on the vent.  The vents aren't that big on the trucks and will surely block air. The phone is larger than the vent. That would be like turning the vent off.  Bad choice..
Edited by mafd2
Cupholder ones are nicer than vent mounts. Also, having the air conditioner on full blast against the back of the phone can mess up the battery. I agree with the above statement.
Try checking into a cupholder version? Cupholder's placed pretty high. I looked into that but my Android Auto does a decent job so I just stick my phone in the cupholder without needing to see the screen.
Not into vent ones, especially right now when it's 110 degrees out. Cupholder ones take up a cupholder... And am already down one on my bench seat config because of the new shoulder seatbelt strap on the middle seat.
Looking for one positioned at or near the top of the dash to the side of the steering wheel. Mine now is positioned perfectly, just keeps falling off.
Edited by scdaren
Try RAM Mounts. They are pretty good. A little spendy, but worth it in my opinion.
Nothing will stick to a dash with weight pulling on it especially in 110° temps and 140° interior temps.
Agreed. There has to be a better way. Why haven't car manufacturers dealt with this issue, I mean it's 2019 and states like CA where I am legally required such mounts to be able to use your phone while driving!!! At least give us a smooth square somewhere on the dash that a suction cup will stick to.
Seems like there are so many of these trucks, someone should be designing and making a mount that will attach to certain points on this dash.
There's companies that make a suction windshield mount. Not sure about visibility or if it's legal in your state. Google cell phone windshield mount under images.
Yeah the one I have will suction to the windshield... But illegal in Calif. to have anything attached to the windshield, though I see Uber drivers with that setup all the time. Also the windshield is kind of far so you have to extend the arm of the mount way out and that makes it a bit bouncy.
Just ordered a nice cup holder one from Amazon
Cellet PH600
Edited by MacLaren
Personally, I don't like the suction cups on the windows or dashboard.  In the past, I've use the Panavise custom dash mounts with a PortaGrip holder.  They don't have one available for the new body style yet so I made my own mount using the following to parts.  My truck doesn't have a trailer brake controller so I screwed the swivel mount into the blank filler panel.  I figure I could replace the blank panel for about $10 in the future (PN 84161640 according to the sticker on the back).  I'll try to post a picture tomorrow in the daylight.
Swivel mount with AMPS mounting pattern
https://www.amazon.com/gp/product/B00SV2LXTG/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
Panavise PortaGrip phone holder
https://www.amazon.com/gp/product/B00CO3HBK8/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,881 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
