Does anyone have any phone mounting options that's working out real well for them?
Right now I have an iOttie mount, that overall works pretty good as far as holding the phone right where I need it, but can't get it to stay stuck to my dash in hot weather.  The rubber adhesive pad it suctions onto keeps coming off.  Hoping to find some better solutions.
I just got this one:
https://www.amazon.com/gp/product/B07NPS6S41/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
So far so good.  It grips the cup holder pretty good and puts it right where I need it.  This was bought for my wife’s Equinox, but I think it would work well in the truck if you’re willing to give up a cup holder.  There are ones with longer flex tubes so give some thought to how long you want it to be.  I looked at the Weather Tech, but it was too expensive for what it is.
13 minutes ago, rmkmb said:
Definitely wouldn't get one that goes on the vent.  The vents aren't that big on the trucks and will surely block air. The phone is larger than the vent. That would be like turning the vent off.  Bad choice..
Edited by mafd2
Cupholder ones are nicer than vent mounts. Also, having the air conditioner on full blast against the back of the phone can mess up the battery. I agree with the above statement.
Try checking into a cupholder version? Cupholder's placed pretty high. I looked into that but my Android Auto does a decent job so I just stick my phone in the cupholder without needing to see the screen.
Not into vent ones, especially right now when it's 110 degrees out. Cupholder ones take up a cupholder... And am already down one on my bench seat config because of the new shoulder seatbelt strap on the middle seat.
Looking for one positioned at or near the top of the dash to the side of the steering wheel. Mine now is positioned perfectly, just keeps falling off.
Edited by scdaren
Try RAM Mounts. They are pretty good. A little spendy, but worth it in my opinion.
  • Thanks 1
Nothing will stick to a dash with weight pulling on it especially in 110° temps and 140° interior temps.
Agreed. There has to be a better way. Why haven't car manufacturers dealt with this issue, I mean it's 2019 and states like CA where I am legally required such mounts to be able to use your phone while driving!!! At least give us a smooth square somewhere on the dash that a suction cup will stick to.
Seems like there are so many of these trucks, someone should be designing and making a mount that will attach to certain points on this dash.
There's companies that make a suction windshield mount. Not sure about visibility or if it's legal in your state. Google cell phone windshield mount under images.
Yeah the one I have will suction to the windshield... But illegal in Calif. to have anything attached to the windshield, though I see Uber drivers with that setup all the time. Also the windshield is kind of far so you have to extend the arm of the mount way out and that makes it a bit bouncy.
Just ordered a nice cup holder one from Amazon
Cellet PH600
Edited by MacLaren
Personally, I don't like the suction cups on the windows or dashboard.  In the past, I've use the Panavise custom dash mounts with a PortaGrip holder.  They don't have one available for the new body style yet so I made my own mount using the following to parts.  My truck doesn't have a trailer brake controller so I screwed the swivel mount into the blank filler panel.  I figure I could replace the blank panel for about $10 in the future (PN 84161640 according to the sticker on the back).  I'll try to post a picture tomorrow in the daylight.
Swivel mount with AMPS mounting pattern
https://www.amazon.com/gp/product/B00SV2LXTG/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
Panavise PortaGrip phone holder
https://www.amazon.com/gp/product/B00CO3HBK8/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
