Has anyone figured out the way to not have my phone volume lower all the way to its lowest setting when I turn the truck on and the phone connects to bluetooth? I messed with settings on my IphoneX, but nothing seemed to work.
Thank you!
Thank you!
THIS HAPPENS when an iPhone is connected through bluetooth, the iPhone defaults to the volume button on the phone, not on the radio.
In order to hear "line volume" either connect through USB cable/CarPlay OR turn the volume on your phone to its highest setting.
So you want me not to use bluetooth and plug my phone in every time? If you use bluetooth, it turns down your volume every single time, to the lowest setting. No matter what.
Thats because you leave the volume on your phone down.
the bluetooth connection doesn't have the bandwidth or the speed that the lightning connector/USB has, which is why Carplay doesn't work unless you're plugged in. (too much data to transfer over bluetooth for a "real time" experience)
Sorry, We are talking 2 different things I guess. When you get in and turn the truck on, it lowers the ringer volume all the way down. Many people are complaining about this and there is no fix. Doing the "change with buttons trick" doesn't seem to work for most people.
 But the bluetooth and Apple car play information you are stating is not correct. My wife's car does not need to be plugged in for Apple car play to function.
sorry.. good luck fixing the problem.
Same issue.  I have disconnected Bluetooth until a solution has been found.  Otherwise, I forget to turn the phone volume back up and I miss texts & calls.
I have only had this 19 a couple of days but I kept missing calls and finally figured out same as these other guy that every time I drove this truck and the phone connected to Bluetooth the phone ringer volume was turned to the lowest level.
I have a theory (tongue in cheek) maybe it is OnStar punishing me because I turned down their high pressure sales pitch when I picked the truck up......... Quote "Well if you don't give me a CC number you don't get your free month of OnStar"   This might be considered a quid pro quo?
  • Haha 1
I personally think it does this simply for safety reasons.  My Android phone does the same thing when connected via blue tooth, it turns on a "Do not disturb" mode which mutes the ringer and notifications on the phone.  Calls do go through hands free on the truck but I miss texts, and again I think it does this so that you are not having to handle the phone while driving.  If connected to Android Auto via USB cable I get notifications when I get texts via Android Auto and it also reads them aloud if I so choose and can also reply hands free.
I recently switched from Android to Iphone due to everyone in my family having one. Because of this issue, I switched back to Android. The only time I had this issue was with the Iphone. Android works fine.
    Chris80s
    Chris80s
  • Who's Online   4 Members, 0 Anonymous, 906 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
