I've noticed my truck is very unstable when going over bumps on the road, doesn't really matter my speed, but the truck becomes very "loose".  Anybody else notice this?
Do you have Z71 suspension package with the Rancho shocks?
What trim package if so? Trail Boss or other?
2019 RST Z71 Crew Cab Reg bed.  Yes, I believe they are Rancho shocks.
Well IMHO as I have stated before in the 2014-2018 truck section, it is the Rancho shocks.
Trail Boss and AT4 are equipped with the Monotube version which is better than the twin tube design on your truck.
Twin Tube Ranchos are not dampened very well and are lackluster on roads where there are railroad crossings, pot holes, washboard sections etc.
They are also spongy and the rebound is off when off roading.
Edited by Sierra Dan
Please tell us about your tire size, air pressure, etc.
Lower profile tires and over-inflation will make the ride worse no matter what shocks you have. Trucks do ride rougher when completely unloaded.
Fresh from dealer when I brought it home the truck had 41psi in each tire, I took that down to recommended level, right around 35
I also put new tires on the truck and it does the same, these tires are Cooper Discoverer AT3 XLT - 275/70/18
Edited by derek01f
It's been discussed here. I got flamed when I mentioned that!
That's why I have ten on my ignore list. The back end fishtailed so badly I nearly ran over a guy on the side of the road. It was a straight road with dried dirt on top from a recent storm. I was so surprised it fishtailed when I wasn't hitting the gas or braking on a straight road.
Solution: the tires were inflated at 45 psi or 44, well above the recommended 35. I have no idea why it came like that and letting air out helped a bit. The next two times, it fishtailed but wasn't as bad as the first one. I was so mad, I nearly ran over a pedestrian. Like you, I have an RST 4x4 so I know exactly where you're coming from.
I was doing around 80km/h and hit a washboard area in the road.  The truck began to yaw and was nearly sideways before I was able to recover it.  Stabilitrak never kicked on. Road was dry.   Bounce was so bad the tonneau cover actually detached and landed on the road.  I have the max trailering package so the suspension is tight to begin with.  Scared the hell out of me for sure.  Bumps, potholes and train track crossings are rough but not to the point of losing control like the washboard area did.  Never experienced anything like it in my past GM pickup trucks.
It's not just the Z71 and max tow packages.  I have the RST non-Z71 and like previous pick-ups it too fishtails on washboard roads.  Unfortunately this is the worst I've ever seen and I buy a new chevy every three to four years.
Like others have said, adding weight to the back will help but it's not going to go away completely.  Bilstien 5100 shocks also help but there is no real solution.  Heavy springs designed for the payload/ towing wars combined with a now lighter weight back end means more fishtailing.
Welcome to the Z71 T1 walking rear end club.
You're not alone, fellow Rancho victim. Lol
Well I’m kinda glad to see it’s more than one person. Crappy problem to have, I noticed it early on and no matter what I have done, wheels/tires or different air pressures it all reacted the same way.
Shocks are on top of the mod list right now. I’m waiting for fox to release a 2.0 coil over good for two inches of lift so I can do something like a trail boss setup
Fox coil overs will most certainly help smooth things out.
Mostly, this is just the result of trucks getting lighter, but able to carry more payload. Stiff rear ends when empty.
Exactly the same situation I was in. That is a liability issue, I was more angry over the fact I could have killed the guy walking on the side of the road. GM fanboys got all over me on this, questioning my experience, etc. "My Ford did the same" I've driven 4x4's and none were this bad. I was going about 70 km/h, maybe 80 km/h when it happened. That is why my next car isn't going to be a Chevrolet unless they address this.
    ncleg
    ncleg
  • Who's Online   5 Members, 0 Anonymous, 684 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
