On 9/14/2020 at 9:07 PM, JB23 said:
I passed through Fresno last week and the dealer there had two sets of flares on display (I don’t recall the colors - one was definitely white), but they are willing to sell them off the wall.
what dealer was this?
thanks
thanks
Kylant- it was Fresno GMC. Parts is closed on the weekends, but the number is ‭(559) 431-2020‬
On 9/16/2020 at 8:33 AM, swaptrex14 said:
That’s tempting to call them but I bet from a dealer they’re a lot more than $495.  Hopefully mine will get shipped soon.
That’s a steal at 495.00. I will say, that they did honor the 15% off coupon that GM was offering to owners on the accessories page.
I can't get a straight answer...
accessories website does not show them anymore.
local dealer says they are available, I placed order on saturday. I was not convinced they are available, but the guy said they were
today I call another local dealer to see if they have them in stock. No, and he also says they are "red flagged" by GM with no ETA of availability
So, I call the dealer that I ordered them from on Saturday. Talk to another parts guy, He says they are available, and they should receive them on Wednesday ??‍♂️
Did you try the Fresno dealership, Kylant? The parts guy did say to me that supposedly, GM was trying to get them back for 2021 builds since they will be offered as a standard option...
Now, I don’t know how true that actually is, but all of the sudden they have ALL disappeared and are impossible to find.
i didn't call them. I am kind of stuck right now since I paid for them at the local dealer. If they don't show up on Wednesday, I will get more clarity and see if they are actually available. if not, i will get a refund and call Fresno
update:
flares did not show up yesterday. after 2 calls today I was finally told they are available, but the are on a LPO hold with no estimated ETA. Basically they are holding all painted flares in order to put them on new trucks.
the only ones available are carbon black and cajon red tintcoat. both of which, i believe, are discontinued colors for next year
2021 2500 order guide
SF6         LPO, Body color wheel arch moldings, (dealer-installed)
1 -  Requires exterior paint (GAZ) Summit White, (GBA) Onyx Black, (GSK) Cayenne Red Tintcoat or (GAN) Quicksilver Metallic. Not available with (ZW9) pickup bed delete, (VQK) front and rear Black molded splash guards, LPO or (PDH) GMC Interior Protection Package, LPO.
2 -  Requires exterior paint (GAZ) Summit White, (G1W) White Frost Tricoat, (GBA) Onyx Black, (GSK) Cayenne Red Tintcoat or (GAN) Quicksilver Metallict. Not available with (ZW9) pickup bed delete, (VQK) front and rear Black molded splash guards, LPO or (PDH) GMC Interior Protection Package, LPO.
3 -  Requires exterior paint (GAZ) Summit White, (GBA) Onyx Black or (GSK) Cayenne Red Tintcoat. Not available with (VQK) front and rear Black molded splash guards, LPO or (PDH) GMC Interior Protection Package, LPO.
4 -  Requires exterior paint (GAZ) Summit White, (G1W) White Frost Tricoat, (GBA) Onyx Black, (GSK) Cayenne Red Tintcoat, (GAN) Quicksilver Metallic or (GCI) Carbon Black Metallic. Not available with (VQK) front and rear Black molded splash guards, LPO or (PDH) GMC Interior Protection Package, LPO.
1, 2, 3, and 4 are trim levels  -  SLE, SLT, AT4 and Denali
They show not available on base Sierra.
On 7/23/2020 at 6:10 PM, Spangled said:
I took my truck to my local body shop and we matched it with paint chips. I went with a tri coat paint which was a little more pricey but I thought it matched the best
did you or your body shop smooth the flares first?
I may have an extra set that I will take to the body shop and have them painted if the price is not too high
thanks
thanks
I purchased the primered/ready to paint flares from GMC Accessories. I'm not sure what they did to them to prep them but I doubt there was much sanding involved, they were fairly smooth to begin with. They used a tri coat paint ($$) and I think the total to paint all four was about $450.
thank you.
do you happen to have the part number for the primed flares? I cannot find it anywhere
18 minutes ago, kylant said:
thank you.
84237184
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
