On 9/16/2019 at 2:28 PM, The 54 said:
I could only find one of the three 7mm bolts to get the step off anyone have pictures of the three 7mm bolt on the step?
are you talking about step 1?
the bolts "under the pad" are the torx screws later on in process...
please clarify and i can help with pics
I only found one of the 7mm bolts behind the step by getting under the truck
This is passenger side.
This is step 1.
Mods can we unlock my first post so i can update it with better pics?
c285fc0afd43d314547facd4f35fba7b.plist
Edited by PabloK
Tips back from the powder coater!
They look flawless, should be tough as shit
Those look hella good! By any chance did you get a quote for hydro Dipping? Just curious to know if the charge for PC and Hydrodipping is close. I’m thinking about having a carbon fiber pattern hydro dipped and the charge is about $80 for both.
@PabloK thanks for the write up! This saves everyone an immense amount of time for this mod. I’m considering hydrodipping the exhaust tips, just need to find a place to do it for me in DFW area.
Having some trouble remembering how to put on the exhaust tips, the little threaded pieces for the screws go on the exhaust tip themselves correct? The you just put the screw into the hole on the truck and tighten it up?
Alright, tips installed. Looks awesome. Pics don't do it justice. I highly recommend this to everyone. Technically you don't have to remove the side steps to replace the tips. The space is tight but it's possible with a ratcheting wrench and a lot of elbow grease. This is how i installed it with the help of a friend.
  • Like 5
Yea baby... nice
Ours turned out almost identical in finish.
If not properly set, those things will drive you nuts, I’ll try and get a pic of how they go
5 hours ago, PabloK said:
Yea baby... nice
Thanks. Loving every minute of it.
I got mine back on earlier thank you !
  • 3 months later...
Great write up, pulled mine off in 10 minutes and dropped them off at the powder coating shop.  $40 for the pair seemed like a great deal to me
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
