I cant seem a way to figure out how to lock my keys in my AT4 without my doors auto unlocking.  I
do this in my other SUV and use the app to unlock so I cant lose my key.  I do this when I go places like amusement \ water parks so there is no chance I can lose my key and be stuck 100+ miles away.
Anyone know what setting im missing to accomplish this?
Thanks
I believe an electrostatic bag might work. You should be able to put you keys in it and lock the truck.
Anyone else have any knowledge on this?
I'm not sure on the new ones since the keys are setup as a keyless fob but on the older trucks you could go into the radio and turn off the safety lock that unlocks the door if you have the door open and hit the lock button. I think it's auto unlock or something like that in the radio.
I'm not sure how but it can be done. I will take a look at my settings. I lock the key fob in my truck all of the time. Also a point of interest, GMC has an accessory keypad (a knockoff of Ford's) that I had mounted on my door. ($250 installed at the dealer) that works great so far. You can lock or unlock the truck and therefore the tailgate without the key fob. I lock my keys in the truck all of the time and dont even need a phone to unlock.
I can lock my keys in my AT4 with my phone, sometimes the button on the door works. There is a setting to turn off the 3 horn honks that tells you you locked your keys in the car, I turned that off maybe that has an effect.
  • 1 year later...
2021 GMC Sierra 2500
I need to be able to lock both key fobs inside the truck. I had a touch pad installed so I could reenter.
The electronics will not allow me to lock the fobs inside. I surmise there must be a way to disarm the auto-unlock.
How can I do this?
How can I do this?
It's on the settings section of your radio
  • 1 month later...
Solution:
I had a GM touchpad lock installed at a cost of $145 plus less than 1 hour labor. Still GM support and the service manager did not know what it would do.
1. I purchased 2 "Faraday" pouches (9.95) for my fobs and hide them anywhere in the truck or the bed. The truck now does not sense their presence.
2. I can open the doors with my custom combinastion. I can lock the doors with the touchpad command.
3. The big difference is that if someone enters the truck they cannot start it because the sensor does not know if the fobs are on board or not and the potential thief doesn't know either.
4. If I have left fobs in the truck I can return from fishing or hiking and get in with combination.
No one at two dealers nor at GM support knew any of this. If there is a disable command in the radio I could not find it or it would not address an on-board fob.
  • 1 month later...
10 hours ago, patischof said:
So, did you manage to accomplish this? I would also like to have this, but I don't know what I need for that. I thought I might need an electrostatic bag. Well, that didn't work. I tried to change some settings in it, still didn't work. I went to the dealer, they told me I should get a newer key that costs almost 1k!
You need the touch number pad for the exterior of the driver's door.  It's available via GM Accessories, and requires the dealership to do a computer programming for the touch pad.
Thanks
get a spare key n put it in your wallet, that's what I did
The easiest non tec way would be to wear it around your neck via a neck chain. I use to keep a spare key on my tailgate post tied to a wire. On one truck I could slide it behind the gas cap lid bracket. So these high tech trucks still have keys? If not then sentence one.
Go camping outside of cell range and accidentally close the door with the keys inside while packing up.  Regardless of the owner's manual saying it won't, it's sure-fire way for the vehicle to lock itself for some reason.  Ask me how I know.
  • Haha 2
I've had that happen too.
yeah i had that happen too, that's why i always leave a window down just enough to get my arm in to open the door.. a smart guy would go to a locksmith and get him to cnc a nonprogrammable key to hide somewhere.
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
