noticed yours was built in mexico, thought they where all built in Indiana.
Maybe just the dmax engines are built in indiana. Final assembly elsewhere
Sent from my SM-G973U using Tapatalk
3.0L engine is built in a plant in Flint. (Flint Engine Operations ).
1500 Crew cabs are assembled in Mexico.
Edited by afterburner82
there`s a sticker on my left frt door that says fort wayne assembly with UAW an GM on it .so I have to assume that's where final assembly took place .
Not driving much but was a deal I could hardly pass up.
Being in Texas it shows Mexico assembly as well.
1 hour ago, jnissen said:
Joined the club as well.
Crew cab short box?
Ft Wayne, Indiana assembly builds some crew short box. I am pretty sure all the CarbonPro trucks are built at Ft Wayne because the carbon bed supplier is very close by. I don't think the engine choice has much to do with where the truck is built though.
On 4/27/2020 at 5:02 PM, pewterliftedz said:
Do you have the "diesel off road package"?  I wonder why your payload is 200lbs lower than mine.
The regular 6.5 box trucks has a lower payload rating compared to the short 5.3 box trucks, the off-road package may also add a few pounds over the Z71 but I seriously doubt it.
Edited by Chevy Big 10
So we got our 2020 3.0 Crew cab/short box denali in December and only had the chance to put a couple thousand miles on it.  ‘This week we finally got to take it on our first big trip out west.  We are half way through the trip and going through SD and WY we avg’d about 75-80 mph. We have 4 people in the truck and bed has luggage and supplies and we are getting about 25mpg. I realize if we went 55mph that we’d probably get closer to epa numbers but I’m pretty happy with this result. Additionally before this trip, with around town driving, we were getting consistently getting 24-25. We took this same trip a few years back with our suburban and averaged about 18-19 mpg.
Overall truck is doing very well and no issues- Its a pleasure to drive and comfortable for all.
  • Like 4
On 4/18/2020 at 10:38 AM, ChuckTaylor said:
Anyone towing in the 7000-9000 lbs range care to comment?  Debating between this and a Diesel HD - tow about twice a month, with a few weeks of straight towing here and there.
Yes, i'm towing a 7x16 enclosed. 7000 lbs is very comfortable for this truck. Only on steeper grades will it drop from 10th to 9th with cruise set at 65-70. Good news is the tow/haul mode is very well tuned so it will hold 9th for duration of the hill and prevent gear hunting like the gassers tend to do. Furthermore, 10th and 9th are such a close gear ratio that you won't even notice it if you are looking for it. I can't speak for 9000+ towing but unless you regularly tow in very hilly terrain, there's ample low end torque, smooth, smart and quite transmission works with it flawlessly.
PS - anyone not sold on 3.0 vs 5.3 gas, wait until you go down a steep hill in tow/haul mode and listen to the turbo spool as it's vanes close to create back pressure. Truck will automatically down shift and turbo works to slow the truck down saving your breaks. Might not mean much to you but it does to me:)
Very interesting thread after 28 pages. I've been lurking as I'm considering a new pick up come later this fall and leaning towards a 2021 Silverado 1500, and now considering the 3.0 Duramax engine. It would be my first diesel so I am as ignorant as they come in regards to diesel engines. For those who have experience, do you see an issue with me only driving it 5,000-6,000 per year....it's going to sit a lot and mostly get used on the weekends for hunting, fishing. camping and long highway trips to see family. Thoughts?
Anti Ignorant Rule #1.  Put diesel in it.  (Dont laugh, when you're trained to head to the pump, diesel isnt on you mind)
Mine is used for weekend hauls and very short trips occasionally during the week (otherwise I use my car).  So far, totally content. tow a boat 9000lbs and and enclosed trailer around 2500lbs.
1500 miles and I still have not noticed a regen - although Im sure its happened. I guess that is a good thing.
Edited by steve841
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
