Oil leaking after oil change...
I enjoy this thread.  "If you want something done right, do it yourself," is the major theme.   Many of us are forced into trusting others to do our chores when we no longer have the physical ability or space.  I think once you learn to trust others (delegate) most of us learn that there are other people as competent, if not more, than us.  We can justify distrust by horror stories that we've read or heard about automotive service centres.   In reality, I think such stories pale in comparison to some DIY disasters!   I for example, learned what an oversized self tapping oil pan drain plug was when changing the oil on my sister's brand new '67 Falcon!  I am sure many DIY'ers  have such tales.
  • Replies 32
You definitely have to know your limitations.  But I honestly think everyone should know how to change their vehicle oil from the time they own their first vehicle.  Male or female, doesn't matter.  My girls know how to change oil with me since they were in diapers.  Hahaha!
Pbly not your issue but if you live in a cold climate and change filter in winter and have alum block some oil filters need more than the typical qtr turn past hand tight to seal. Wix wants a full one turn on alum block esp if installed in warm shop then outside in minus 0 weather filter will leak  if only tightened typical qtr turn past hand tight   Not an issue in warm weather but cold winter for sure
Been there
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
