6 hours ago, Justin Van Patten said:
Looks like you can add an OEM and have the factory program it.
This is only installing the switch in the dash. The brake controller goes above the spare tire. I can't find any dealer that will program or install the factory one.
Watch the first 2 minutes, he says the factory one didn't work....
Guys and gals.  Its pretty cut and dry.
The Factory Integrated Trailer Brake Controller CAN'T.  BE.  ADDED.
Quote
#PIT5828: Adding Integrated Trailer Brake Controller RPO JL1 - (Mar 29, 2021)
Subject:  Adding Integrated Trailer Brake Controller RPO JL1
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
Escalade
2021
All
All
All
All
Chevrolet
Silverado 1500 (New Model)
2019
All
All
All
All
Chevrolet
Silverado
2020-2021
All
All
All
All
Chevrolet
Suburban
2021
All
All
All
All
Chevrolet
Tahoe
2021
All
All
All
All
GMC
Sierra 1500 (New Model)
2019
All
All
All
All
GMC
Sierra
2020-2021
All
All
All
All
GMC
Yukon
2021
All
All
All
All
Involved Region or Country
North America
Condition
Some customers may request the factory Integrated Trailer Brake Controller (RPO JL1) be installed on their Full-Size Pickup or SUV when the vehicle was not ordered with the option.
This is to advise you that, if the vehicle does not have the option (RPO JL1), it cannot be added to the vehicle.
Edited by newdude
  • Thanks 1
They still won't get it.... 😉
  • Like 3
FWIW The aftermarket, under dash controller offered by your dealer will work well and will disappear from sight when the novelty wears off.  I no longer tow a trailer with brakes and could easily remove my "plug 'n play" controller but it's not worth the effort..
Apparently NOT! Here he is installing a Curt Spectrum in place of his failed attempt at the OEM ITBC.
  • 3 months later...
Just got off the phone with the local Chevy dealer. parts department can order the brake controller kit from Chevy $370.00
installed. They did need the last 8 digits of the VIN number, which leads me to believe it is not available on all trim levels, but I could be wrong. also the computer have been jail broken, (you have to send them your computer, they allow you to make about 3 changes, and it cost about $1,200 bucks.) or you can stack an aftermarket computer to allow you to make all the changes you want. This is how they are adding turbo's, and nitrous to the Vettes.
Not a fan of the integrated brake controller, my 6K lbs trailer stops better with my grand cherokee than it does with my truck, gain on the GC 6, gain on the truck 10. I am quite disappointed the GC stops better and shorter distance every time even on panic pedal mashing.
Edited by Greyhound6.2
  • 2 months later...
On 9/11/2019 at 8:12 AM, Smoothbassman said:
It's possible to get the factory one installed.
I got mine done on my 2019 Trail Boss. It was 300 bucks with the parts labor and software included at my dealer.
The wiring is already there for LT and up Chevy Trucks. Just needed the controller and the software. 30 minute job at the shop.
Which controller did you install? Is it the one with the round twist knob or the one with the minus/plus sign and slide control? After programming, do you get all of the brake control features on your radio or on your dash cluster like the trucks that came from the factory with it? I’ve been playing tag with my dealership for a couple weeks now trying to get mine functional and they can’t figure out whether or not they’re going to be able to. I don’t wanna take it in there and pay $150 programming fee with no success....
  • 4 months later...
I'm glad to hear you had success installing yours! I have a 2020 Trail Boss & just installed the switch myself & waiting for the shop foreman at the dealership to call me back to see if I need to have it programmed.
Did you have any luck installing OEM brake controller? What did you tell your dealership  to get it programmed?
What kind of idiot company sell a truck with the trailering package that doesn’t include the trailer brake.
GM sells the aftermarket trailer brake on my Chevrolet.com.
total B.S.
  • Sad 1
total B.S.
I get what you’re saying. It does make it confusing, but you have to remember that if it breaks people need to be able to replacements.
total B.S.
I get what you’re saying. It does make it confusing, but you have to remember that if it breaks people need to be able to buy replacements.
Edited by Jrodpic
  • 4 months later...
On 4/8/2021 at 7:26 AM, ericarenee said:
YES . Its factory controller..  i  Requested to be installed as part of the sale. I went back when the  tags came in and they put it in. took them only a few minutes or so .As i said the Wiring Pig tail was in the Glove box. Gm saves   25.00 by not just installing  it standard with the Trailer package.
Does anyone have a resolution on the factory controller issue.  I installed and it is not working  - 2021 Chevy Silverado 1500 Custom (Trail Boss)
  • Sad 1
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
