If the UAW would get back to work, I would have received my coax cable. All parts shipments are on hold because of the strike.
Wow!!!
Yeah I forgot about the strike.
Sent from my SM-N960U1 using Tapatalk
On 9/16/2019 at 5:03 PM, Boda1985 said:
Here is another diagram that shows the wire to the mirror. So with even more research I learned that camera is for the mirror only. So this should be easy to install. Need the mirror, wiring harness and camera. I assume you don’t need software update if it is all just in the mirror.
So is the wiring harness not already installed? I was under the impression we would only need the mirror and the camera.
No, you’ll also need the coaxial cable that goes from the camera to the mirror. There SHOULD be the mirror power plug in the headliner regardless, but the video cable will not be there.
That was my instance on my 2010 camaro ss. That year no option for rear view camera, didnt become available till 2011. But the plug was there.
Sent from my SM-G960U using Tapatalk
Does the coax connection look proprietary or can we pick one up somewhere else maybe?
I can't wait to find out if this works!  I'd love the review camera.  I'd really like the side mirror cameras, I'm so mad I didn't realize the trailer camera package included side mirror cameras. I should have test drove more, just assumed for $250 you only got the plug for the trailer camera and big truck/standard box those cameras would be awesome for parking.
Thank you all for posting, what you've learned!
On a side note it's awesome to find stuff works with added parts.  My basic trim Acadia was missing a bunch of dic stuff (range, tpms,etc) I was able to knock out a cap and buy a switch that just plugged in behind the dash from gmparts for $15.  Instead had it all.  Dealer told me they didn't think it was possible, maybe could do it for a couple hundred dollars.
Edited by Chris Hronek
Added a thank you
Coax is proprietary. I have tried to make my own with RG56 and the connectors, unfortunately I can’t test without the camera. UAW get back to work so I can get my parts!!
  • Thanks 1
On 9/17/2019 at 12:23 PM, FiatDale said:
I’ve got the mirror and brake light coming. Unfortunately with this strike it’s put a hold on these special order parts, so it may be a little bit until I get to installing and making a harness.
To the comment above, most dealers will say it’s not possible to add after the fact, so I’d save your breath. Either attempt it on your own with more research and then report back to them, or don’t try. Most dealers will not want to mess with trying to reprogram as they don’t know how.
Would you share the part numbers please?  Also, besides the camera and mirror .... is there a harness and part number?
Thanks, Steve
Thanks, FiatDale ..... I'll add that part to my shopping list
Steve
13 hours ago, FiatDale said:
Yes, you’ll need the coax cable which will be special order: 84335461
How much was the cable?
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
