I just swapped out my textured xm antenna in my 2014 Silverado LTZ for the newer style color matched one.  Install went fine, but when I started up my truck the radio screen said “check xm antenna” and the reception was terrible.  I did an xm reflash and that did not help.  So I swapped back to my original.  The message went away and reception came back.
Anyone who swapped shark fins ever run into this problem?  Do I need the dealer to reflash?  Is this a case of the 2.0 HMI not compatible with the new antenna?  Or did I just get a bad antenna?
What's the new antenna looks like?
Sent from my SM-N975U using Tapatalk
Like the old antenna except slightly larger , smooth and painted black instead of black textured plastic.
I rather keep the old one, unless you want to spent some $$ for adjust a new one, no one noticed a new one I think.
It took me a minute to figure what you were trying to say in that incoherent response.  I really appreciate your unsolicited opinion.
Anyways, Does anyone have any insight into how I can make this mod work for me?  Because I do notice the difference.
  • Like 3
If you plugged in all the way and it's static then I'd say the antenna has issues. Is it OEM? New or used?
Was definitely plugged in fully, and is a brand new factory antenna.  This seems to be a 2014 problem.  I’ve talked with another guy on another forum with the same issue.
I also swapped to the painted antenna, and lost XM.   My issue was that my 2014 Antenna only had the purple connector, and the new Painted Had the Same purple antenna, but also a gold connector.  I believe that the XM antenna is the gold connector in the 15+ trucks, where it was in the purple Connector in 14.
I believe that its as simple as swapping the antenna switcher that is on the passenger side upper dash under the speaker trim, and XM cable, but I would like to get a thread together and see what part numbers are, as I don't have access to GM documents.
Another member, Enduro Guy, was simply giving you an opinion.  It is sometimes good to give our plans a second thought.   There are many discussions on this forum regarding these shark fins and a popular mod is to paint the existing fin.  Some do this while the fin is in place.   Most of the mods I do are for my own visual or functional benefit and I'm not arguing with the idea.  However, sometimes the changes required to make an idea work negate the value of the mod, imo!
I heard that the purple connector is still XM and the gold one is for the Onstar WiFi
  • 4 weeks later...
On the 14/15 trucks with only the purple connector, Wire #2 is xm, wire #1 is onstar/compass/gps. You gotta take the xm module out of the 14 antenna, wire #2, and install it into the new antenna. I'm currently working on the gps compass issue now as well. For some reason, I cant get the compass to constantly work, just shows "--" where it shows direction. GPS and onstar work perfectly though.  Weird how compass doesnt work but gps and onstar do. All of that is on wire #1another new antenna is on order so I'll see how that goes.
Edited by RACERX7775
With my painted 15+ antenna on my 14, my compass works 100% as does my Nav, on Star is not active so I don’t know about that.  I just get the check XM antenna message.
So you have no onstar and no xm. Does your onstar light up red on your mirror?  Most of us still want all the functions. Was your antenna a 2 wire or the 3 wire with the gold connector.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
