looking at the new 2500 HDs.....the gvw on these trucks are over 10k. obviously once over 10k you enter a whole new game of bullshit. is this new? i mean my 2015 3500 has the derating to 9999 or whatever. i didn't think the 3/4 tons passed the 10k mark.
looking into it further...if you want nice wheels, you have to have the 10,6 GVW. if you want to keep it at 10 you have to have 17" rims. not sure what their reasoning is for this.....but in MA over 10k you need USDOT numbers, if you travel more than 100 miles from home base you need a log book, medical card, etc. its already a pain for my one ton dump i dont need it in a regular pickup.
You can order any 2500 with CGO option that will restrict to 10,000 lb gvw in US and 9900 lb in Canada.
#iworkforGM
Edited by MTU Alum
Are you using it for commercial purposes? Even in MA it appears to state it is exempt for private use. DOT regulations also seem to state that vehicles exceeding that threshold that are used for Commerce must register. Private use appears to be exempt from DOT - but states may require different drivers licenses when you add trailers (even for private use). There are states that offer CDL type licenses when your rig exceeds 26,001 GVWR, without the Commercial part for things like RV’s and such. Some states require that type of license when you have a 10K+ trailer even if the GVWR is less than 26,000lbs. The key to any of it is whether or not it is used in commercial applications. Some states force a commercial registration for pickup trucks regardless, but there are still exemptions for private use.
The new trucks all picked up on GVWR big time.  The 2500hd trucks are GVWR'd almost at the 2015-2019 3500hd trucks.
You can de-rate from the factory to 10,000lbs GVWR.  The way I read it from GM, over 10,000gvwr for business, you need your DOT stuff in line.
The build code for de-rate to 10,000lbs is C7A.
C7A from the order guide:
Quote
GVWR, 10,000 lbs. (4536 kg)
1 - CC20903, CK20903 and CC20753 models require (L8T) 6.6L V8 gas engine. (L5P) Duramax 6.6L Turbo-Diesel V8 engine is not available on the following models: CC20903, CK20903 and CC20753.  This applies to WT trim.
2 - CC20903, CK20903 and CC20753 models require (L8T) 6.6L V8 gas engine. When ordered with (ZW9) pickup bed delete, includes hard touch instrument panel-top pad. (L5P) Duramax 6.6L Turbo-Diesel V8 engine is not available on the following models: CC20903, CK20903 and CC20753.  This applies to LT trim.
3 - CC20753 models require (L8T) 6.6L V8 gas engine. When ordered with (ZW9) pickup bed delete, includes hard touch instrument panel-top pad. (L5P) Duramax 6.6L Turbo-Diesel V8 engine is not available on the following models: CC20753.  This applies to LTZ trim.
With de-rate, keep in mind you will lose payload and you will lose about 5% of tow rating over a non de-rated truck.  If diesel, you will lose a lot of 5th wheel rating.
#iworkforGM
RPO CGO de-rate applies to Custom and High Country trim with 20" wheels only per GM.  However, per the vehicle order guide, CGO isn't even listed as a GVWR RPO code, just C7A.
#iworkforGMtoo
Not for personal use.  NO truck or RV operator is required to have medical card, log book, CDL, DOT numbers, etc.  Those requirements for commercial vehicle operators, such as running a dump truck that you mentioned.   By it very name.... Commercial Drivers License... says it all.  It is not required for personal vehicle operators.  As was stated, there may be some additional license requirements by some states that require endorsements on the standard drivers license, but the majority have no such requirements.
I am in commercial trucking. If I decide at some point to quit the business and use my semi tractor to tow around a large 5th wheel RV, I will not be required to have medical card, DOT numbers, log book, etc....  intrastate or interstate.    I will probably just keep my CDL as it is my normal driving license anyway, including Motorcycle endorsement.  It would be stupid to chuck it out the window.
Edited by Cowpie
  • 4 months later...
#iworkforGMtoo
Where can I find more Information on this?
when ordering a 2020 Sierra through my dealership in MA selecting the C7A code for 10,000 gvwr triggers federal emissions or California emissions(can’t remember which one) why would the gvwr change the emissions? Really don’t want to deal with the DOT number deal on this truck.
thanks
kevin
thanks
kevin
Are you trying to order a Denali?  If so, Denali can't be de-rated per the order guide if the truck requires NE1 or YF5 emissions:
https://www.gmfleetorderguide.com/NASApp/domestic/proddesc.jsp?year=2020&regionID=1&divisionID=2&type=0&vehicleID=21695&section=oi_def&page=6&butID=3
Quote
NE1:  Emissions, Connecticut, Delaware, Maine, Maryland, Massachusetts, New Jersey, New York, Oregon, Pennsylvania, Rhode Island, Vermont and Washington state requirements
YF5:  Emissions, California state requirements
1 - Available to all models with L8T Gas Engine. L5P Diesel requires TK20*53 or T*20*43 models. L5P Diesel Not Available with TC20743 or any Regular Cab models.
2 - Available to all models with L8T Gas Engine. L5P Diesel requires TK20*53 or T*20*43 models. L5P Diesel Not Available with TC20743 or any Regular Cab models. When ordered with (ZW9) pickup bed delete, includes hard touch instrument panel-top pad.
3 - Available to all models with L8T Gas Engine. L5P Diesel requires TK20*53 or T*20*43 models. L5P Diesel Not Available with TC20743. When ordered with (ZW9) pickup bed delete, includes hard touch instrument panel-top pad.
4 - Not available with (YF5) or (NE1) emissions.
Massachusetts is one of the 12 states that follows California emissions requirements for vehicles, so when they are configuring the truck, its forcing NE1 due to where you live, and then removes the C7A option.
Base, SLE, AT4 and SLT aren't affected for C7A.
Edited by newdude
Sorry should have elaborated,
the truck is 2020 GMC Sierra 2500 Double Cab SLT with 6.6 gas, the GVWR auto populated to 10,550.
when applying code C7A it’s removing NE1 and forcing either YF5 or FE9 I believe(ill have to ask the dealer which one it forces again)
Is this an issue in MA?
my dealership advised against it after he couldn’t find a solid answer.
Edited by kag01510
Its probably trying to force FE9 federal emissions on it is my guess.  Being MA is one of the 13 Cali emissions states, it might be a problem.  Not sure how that will play out really unless they try to put the order through :dunno:
Ok guys. For the guys who know more than the dealerships and all. Small business owner here in California. Do I really need to derate the truck to 10000 or else I need to get dot # and what about cdl? Does this actually come up in real life? I’m not even really going to be towing certainly not big things. I want the muscle and 3/4 for lumber loads etc for my construction company. What’s the truth about what I need to consider here?
I would suggest contacting the DMV, your state police, and/or the DOT for that info.
Do you really want to get into an argument with a DOT guy starting off with "Some guy on the internet told me...."
DOT certified inspector here, not a police officer, i own an OTR trucking company and personally do annual inspections on semi trucks and trailers to ensure they are road worthy.    If a pickup and trailer in combo has a GCWR over 26,000 you technically need a CDL and dot#'s IF AND ONLY IF ITS FOR COMMERCIAL PURPOSES. If its personal use i am nearly certain NO state requires anything special, its when it falls under business use that it becomes an issue.
    DM22
    DM22
  • Who's Online   4 Members, 0 Anonymous, 1,691 Guests (See full list)
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
