They only run in v8 mode at idle, no cylinder deactivation. I’ve noticed mine will sometimes idle rough after an “auto stop” restart but not otherwise.
I suspect it might be from the flappers closing and opening due to the exhaust gas pressure being low. I noticed something similar in mine with the factory exhaust. I'm not experiencing it anymore with the cat-back exhaust.
Mine does it once in a while and it is annoying but I do not want to take it back just for that.  I read to run some premium gas in it.  The 6.2L engines love higher octane gasoline.  I am on my third tank of Sunoco 93 octane.  I can say it is better but still hick ups once in a while.  BUT on the good side I am seeing the best fuel mileage since I bought the truck, generally over 20MPG on the highway at 75 - 80MPH.
  • 7 months later...
I have a 2020 GMC Sierra with the 6.2L and its also been idling rough.  I notice it after the dreaded auto stop feature starts the engine.  Not sure what is the issue but I can tell its rough.  I have about 5.900 km on the truck and it started to run rough at idle about 1500km's ago.  At that time I also noticed that when starting it up after it has been sitting overnight I get a puff of blue smoke when I remote start it.  I figured it was the valve guides but hoped it wasn't the piston rings as a worst case scenario.    When I took it into the dealer they diagnosed it was bad valve guides.  I am waiting for the new guides to be shipped in from the US which could take a month because of the pandemic.  Having said that, the problem could be  fouled spark plug because of the oil burning off after I do a cold start.   Use the remote start and stand behind the truck when it starts up and see if you get the blue smoke when you do a cold start in the morning.  The dealer without hesitation said they would replace all the guides on both heads just to be safe.  If you are having a similar problem and the dealer tells you its your valve guides make sure you get all of the guides changed not just the one or two that are leaking.  I am also going to have the spark plug changes in the cylinder that is the issue.IMG_4056.thumb.JPG.f252e6d4a24e973e62db87f4135e20f8.JPG
Good luck
ST
Now that gas is cheap I run 94 octane in Canada. I was using 91 and 89 octane in my 6.2L Sierra. I didnt notice any change.
On 9/22/2019 at 12:05 PM, cbprov said:
my 6.2 in my at4 runs rough at idle any body else have this or is this normal for the engine as it cuts out cylinders
I have a 2021 Silverado with the 6.2 and mine indies rough.  Had it in the shop twice and they say everything is good.  So frustrating
Mine is the same way.  It idles terribly almost like it’s gonna die or a misfire.  Had it in the shop twice and they says it’s normal. Love the truck but seriously thinking of getting rid of it because it drives me crazy.  Come on GM !!’ This is terrible… it’s 2021 lol you would think a brand new truck would idle smooth
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
