Since cabin air filters are a forgotten item most of the time.  I'm guilty.  I figured maybe a little spot on the forum to post up some of the nasty ones.  Here is my 2002 Silverado filters.  I just checked and these have been in there for 2 years and 26 days and have 17,699 miles on them.  I try to change the cabin air filter out once a year but as usual I missed a year. The one picture is what fell out as I pulled the filters out.
  • 2 years later...
14,623 miles 8 months replaced with Bosch 6091C HEPA rated filter. Afraid it might be too efficient.
Thanks for the reminder.  I need to clean the one in my Cruze.  I put a K&N in it.  I figure it just needs to filter out the big stuff, not as important as the engine filter.
I bought the HEPA media cause I got it on sale for $15.99 shipped and after discounts cost me .27 cents!! 🤩
I changed mine for the first time last year (due to change it again, I think it's been around 14,000 miles).
I have reason to believe this might be the original from 2014, as the original owner told me that he did not know that this even existed. I have since added this to my list of routine maintenance items so, well, this doesn't happen again:
  • Confused 1
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
