How have you improved your ride quality?
3 hours ago, mcdavis said:
I'll give/agree with you on everything except, respectfully, speed bumps. Speed bumps serve only 1 purpose: to make you slow way down. They're basically only in high foot traffic areas (shopping malls, neighborhoods, occasionally office buildings, schools). And that's pretty much my point: I can't see any reason to let speed bumps be a factor in a suspension discussion. When I have hit a speed bump and the truck has reacted badly, I've always blamed my speed and never my suspension as I doubt suspensions are designed around taking a speed bump at speed.
Other than the several highly modified and lowered sports cars I’ve had, nothing takes a speed bump worse than the the k2xx with oem ranchos.
I hit like 10 speed bumps a day.
it is a royal pain in the ass to slow down to 3mph when now I can go 15mph. These are speed control speed bumps in 25mph zones that are supposed to reduce speed. With the ranchos my choice was crawl over them, or listen to what sounds like a sledge hammer hitting my dash. With my bilsteins I can slow down to 10-15 mph like every other vehicle on the road. I could even hit them at a full 25mph and the reaction of my suspension would be less dramatic than the ranchos at 5mph.
the ranchos are absolutely terrible
if you find them acceptable you probably live in some place with completely flat and paved roads. No way in hell anybody that needs some suspension travel on a regular basis would not agree with me.
  • Replies 43
11 hours ago, mcdavis said:
Question: almost everyone I see post about new shocks, 5100's especially, say something like "it's so much better over speed bumps". How fast are you guys going over speed bumps? I slow down and take it easy, and expect to feel that bump.
And how much time are you spending going over speed bumps that it even matters? To me, how any vehicle handles a speed bump is a function of how fast the driver goes over it and shouldn't be a factor at all in changing shocks.
With the OEM sets, it was more like when you come off the speed bump, you feel it hard.  With these shocks, you just moreso glide over the speed bumps.  I slow down to go over them but it still made a HUGE difference.  It was virtually unbearable going over them with the OEM shocks.
Thats whats interesting about our factory shocks. Some K2s rideblike a brick while others have a out of control "float" to them. Either way the factory setup sucks. I keep hearing king is the way to go in terms of getting the tuned setup you want.
Sent from my LG-G710 using Tapatalk
I'd had loaners with smaller rims and rancho shocks and they ride much softer over bumps.  Not necessarily "better" but softer.  I just think overall based on this thread, a progressive rate coil spring could be utilized in the front and potentially in the rear with varying leaf spring rates.  That's why I got the sulastic shackles to basically add an extra level of "spring/travel" for unloaded bumps and what not.  The factory should have something similar to the shackles to improve unloaded ride/handling.  I can't tell as much of a difference with the shackles, but the day I drove it away from the garage I had them put on in, and I hit a bump, it was a huge improvement instead of feeling a slamming sensation when going down a dip into a bump.
At this point I think its mostly a result of my tires/PSI.  Having 20" rims its hard to find larger tires without getting an E-load tire range.  The Toyos I have are super heavy and tough, but are probably suited better for a heavy duty truck.
Since they are E-load tires, what do you think the LOWEST PSI you could run for them?  32 in front and 35 in rear is the sticker recommendation in the door for factory tires.  I prefer to run the same PSI in all 4 instead of staggered.  If anything, the fronts should be higher than the rears because there is more weight being applied to the front axle anyway.
Nice! Gotta link to said shackles?
i found after switching over to the z71 tahoe rims the speed bumps became less abusive, the ride was horrible when I had the stock 20" wagon wheels which wher pumped to 40psi, and bounced over speed bumps like a ball
I've gone through the same thing as you and I finally got my truck riding pretty good. 2018 crew, 4wd, z71
I have Bilstein 5100s, 1.3" front lift
Had 275/60r20s, p range, that I was running at 32psi and felt the ride was harsh.  Changed out for the same model tire (Cooper At3 4s) but in a 285/70r17.  At first the ride felt barely softer. But I've put some miles on it and I like it now, firm-ish but no longer harsh.
If you want to keep the 20s the first thing I would do is go to a P metric tire, they still meet max tow requirements.  Nitto makes a 305/55r20 if that fits your truck, standard load.  Check out the g2 tires.  I've not used them but notice they offer some bigger non LT sizes.
The next thing I'd do is ditch that hellwig rear sway bar. A firmer rear sway will form up the ride noticeably.
Do you have any static bed weight?  I'd imagine my tonneau cover, bed mat and 40lbs worth of straps and tools I carry in the bed helps.  I also need a larger spare now and am thinking of getting a LT spare just for a little more bed weight.
If my 17s didn't soften up my ride enough, I was thinking about Rough Country N3 2" lift struts over my Bilsteins. I'm happy now (I think)
I totally understand what both of you are saying. However, my experience has not been like yours.  I have a 2016 CCSB 4wd Z71 that doesn't show NHT code on the tag in the upper glove box. I bought it used with 64,000, now has 102,000 on what appears to be the original Ranchos running stock size tires with no suspension mods. I have a neighborhood I'm in frequently that has speed bumps, and I take them around 10-15 and think nothing of it. The truck handles them well enough that I wouldn't consider spending a dime on suspension because of speed bumps. My expectations might be different, my shocks might be set up different, I don't know. I just know speed bumps aren't a factor in my mind due to how my truck already handles them.
Not saying the Ranchos are great shocks, just wanted some input (that has been given, thanks!) as to why I keep seeing speed bumps mentioned in these threads.
Well these trucks don't come with any rear sway bars, so by adding mine on it helps a lot keep the weight on the inside wheel in the rear end when cornering hard (and it makes a huge difference when unloaded AND loaded).
I have not seen any 295/55/20s in any other load range than E.  295's will rub my front sway bar at full lock, so I can't go any wider.  If anything I would switch to 285/60/20s to get some more rubber and hopefully clear the sway bar.  I'd rather scrub a bit of the inner felt than rub the metal sway bar.
That rear sway may help you corner but it's making the rear stiffer, guess it's your call.
275/60r20 would also work too, which is a 33" tire.  I don't think 285/60r20 will do anything for you being another LT tire.
The Bilstein's are rough too.  A lot of things working against you, one or more has to change to get worthwhile improvement
Gentleman's bet that can’t feel them because they are blown
Actually, they were just checked 1,000 miles ago during the 100,000 mile service and I was told they are fine, no reason to replace. And, respectfully, given how many vehicles I have owned/driven, and that I maintained our construction company's fleet of trucks for 25 years of my life, I'm pretty sure I'd know if I was riding around on blown shocks. Reality is, and I've seen this posted here by other people, the Ranchos probably are not the best shock that could be used in the Z71 package, but they do serve their purpose just fine for some people. For others, they are total trash. I respect that.
A big part is the standard big rim, little rubber look that's in style these days!
I have a WT model with 17" rims and lots of rubber! Helps a lot!!!
I know it's not the popular look on these trucks these days, but it sure helps with my LT E rated tires. I run them at 35 psi and the ride is smooth!
Sent from my XT1710-02 using Tapatalk
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
