14-18 supercharger gains?
BoilerUP
I will message you. Dont want to upset Jacoby or OP. Also I have the tunes part numbers and video. Also explain the pump.
[emoji849]
  • Replies 58
i appreciate any tech info you can offer ,
I have one of those supercharger things you're talking about. My truck goes really fast.
My dyno numbers are that my wife says, "Slow down, do I want to DY? NO!"
Sorry no one gave you any numbers though. I didn't baseline my truck and don't really care to pay for a dyno run after the fact because I've got it running really well now and I just drive it and have fun. In all seriousness, you can get a little or a lot out of ANY SC or turbo you buy. You can leave it conservative and only add 80 hp and tq or turn it up with a smaller pulley (for a SC) and increased timing in the tune and have the boost come on earlier and harder. There isn't a real answer to your question. Not a heck of a lot of guys get before and after dyno logs. I guess the real answer to your question is whatever you want it to be because like I said, you make it add a little power or make it add a lot of power - and that can be done with just the tune alone too.
On 10/7/2019 at 6:33 AM, truckguy82 said:
Also I really hope that was a typo and your didn’t intentionally spell “gains”!with a Z
replacing S’s with Z’s should be grounds for execution
And don't forget that he wrote "sez" instead of "says," too! ?
He's just messing around though. You can tell that he knows how to spell.
I have a 2016 silverado 1500 ltz.
8 speed
Just recently put a whipple on my truck. 4th gen
Nick William's 103mm throttle body.
Also modified airaid cold air.
Borla s-type cat back.
The truck hauls as right now, definitely worth the money.
I ordered KOOKS 1 7/8 headers and high flow green cats.
When I finish the exhaust I am gonna re-tune and dyno the truck.
Whipple is supposed to add 150 hp
Adding the nick William's and straight 4" intake made a bigger difference keeping the whipple tune.
Kooks is gonna take a few weeks to get, I'm having it coated with 2500° coating.
When it's done I can post dyno #'s
Also have grenetilli cold air maf, coil packs and high temp wires
My setup should put me close to 500hp, but gotta spend a shitload of money to get there
Stock silverado 5.3L supposed to be around 300whp.
Alot of people think they need 500 - 600 hp to "feel" the difference.
Stock truck and adding whipple makes a big difference.
I reccomend a cat back to free up the  exhaust flow.
I started with borla cat back, cold air intake and diablo trinity 2 tune.
Made the truck alotta fun...
Would cost around $2000 for that.
When I added a bigger cold air intake grenetilli coil packs, wires, and maf it changed alot.spend 3k and get close,
Otherwise be ready to spend 10k and get the ridiculous power
I’m pulling the trigger on a magnuson kit I already have cat back.
have you tried using the torque app with an ELM obd2, device to see what the ecu says your power level is at?  my stock 5.3 says 320hp using the app.. poor mans dyno.  just an idea..
i have to say after installing a sprintbooster , it really woke up the truck for stop and go city driving.. I see no reason to make a 5500-6000lbs truck go fast other than waste gas and tires.  I would rather build a small truck like an s-10 with a 4.8 and turbo for cheap fun
looks damn good up to 2500, very broad torque, looks like it needs a different drive pulley to get past 4k rpm , they're just keeping the power safe for warrantee
1 hour ago, 1SLOW1500 said:
This is a supercharger graph. Not so great when you see is peaks at 4k then dies off. This is 5.3 and 8lb
What is the blue run, same engine/blower but much lower boost?
2 runs, stock is the lower graph, blower is top graph, its a bit confusing with the colors, the torque usually comes in first with a higher number than hp at low rpms, and usually falls off before hp,
could be loosing power past 4k rpm due to the cam is optimized for the stock truck, might be loosing it in the overlap
The 6.2L's usually dyno around +/- 330rwhp. 5.3L more like +/- 290rwhp.
Josh, 500-600hp to feel the difference over 300hp? I can easily tell the difference between my 5.3L and my 6.2L and its only a 65bhp jump. There is no comparison between the two in terms of felt power.
In all honesty, these new LT's aren't great platforms to build on. We are 6 years into them now and they still cant do what the LS did in the aftermarket. Too computerized, too limited by the stock fuel systems. If I was doing a project car/truck, it would 100% be a Gen IV engine not a Gen V.
