Just a heads up from the "For What It's Worth Department"
Started hearing something coming from the back when I went through deep dips and especially going over those speed control bumps in parking lots, like some loose pipe or 2X4's were bouncing around in the bed; and the back end was a little "bouncy".  Nothing in the bed, so I crawled under and noticed the top right shock mount bolt was gone, and the top of the shock was whacking the mount, frame, and underside of the bed.  I have a dealer-installed factory 2" Rancho Iift on my 2019 Z71 Silverado.
Took it in to the dealer, and while it was on the rack I talked with the suspension technician guys.  One of the techs said he'd seen 5-6 of these, on stock suspensions and a Trail Boss, always the top right shock mount.  Like, it's a "thing" with these trucks.
So, just letting y"all know that you might want to keep an eye on yours, maybe crawl under and take a look every once in a while.  Maybe even the next time you have it in the air for something like an oil change or something, put a wrench on the bolt(s) or even pull it out quick and put it back with some locktite.
Sounds like a dealer install screw up and by him saying he seen 5-6 of these is nothing but a lie so you wouldn't get pissed at them for not properly torqueing the bolt or not tighten at all. Those bolts don't just fall out.
  • Confused 1
  • Sad 1
I replaced my stock rear shocks with some Rancho 9000 adjustables (which are great)  and had this same thing happen. Weeks later I lost the left side top screw and had to get one from the hardware store. I really did tightened them plenty tight . I also found that the right side top screw was loose. I when removed it and noticed that the threads seemed too easy to remove by hand. I used some locktight red on top and bottom of both shocks and it's been fine for a couple of months now.
So the mount didn't come out, just the bolt.  I think a better recommendation would be for check that they are torqued properly.  this is a dealer screwup, and given that dealer admitted to you that it happened 5-6 times there, I would suggest going to another dealer for any further work on your truck...
I know when I replaced the shocks with RS9000's on my truck, I torqued them down to spec, and haven't had a problem with them since (about 50k miles ago).
Edited by davester
19 hours ago, BobbyAlton said:
Thanks, wondering - how many miles on your truck?
Almost 10K.  Includes some semi-serious off road in Utah, Colorado, and Arizona.
I don't think this was a dealer screw-up; although that was, of course, my first thought.  But I've gotten to know the suspension tech that did the work on the suspension pretty well, and he's very thorough and meticulous.  He takes a lot of pride in his work, and was very embarrassed/concerned that it might have been his bad.  I watched him re-torque everything else he did and the rest checked out just fine.
It was one of the other techs there that said he'd seen 5-6 other instances of this happening even on stock trucks. Take it for what it's worth.
I think I did suggest in my OP that others reading this thread to  "put a wrench on the bolt(s) or even pull it out quick and put it back with some locktite."
And, yeah, I can go to another dealer for future work, but who knows what you'll get there?  And, things are different these days than maybe 5 years ago; getting another dealer to work on your truck that you didn't but from them can be problematic on a few different levels.  They can be real pr'ks...... Ask me how I know.......
This happened twice on my lofted 2010 and once on my fathers 16 which was bone stock. Same bolt. Don’t know how or why
Glad it didn't hurt anything. Sounds like an odd occurrence more than anything. People aren't perfect, but based on your description of the tech it doesn't sound like lackluster work.
This isn't a new thing. Same thing would happen on my old '84 GMC Fullsize 4x4. Always the right side upper shock bolt would get loose.
I ended up welding extra support on the frame & making many improvements so that it would stay put.
There is absolutely NO reason for a bolt to fall out if it's properly torqued. That's the purpose of providing torque specs for fasteners... so they don't loosen up. Any tech that says such things is covering their own ass by saying it's a common issue. Yeah, it's common... if you don't use a torque wrench or re-use TTY single-use bolts.
Edited by HondaHawkGT
NAILED IT!
Why not?  Suppose the sleeve inside the shock mount bushing tends to compress or wear just enough that the tension on the bolt is reduced?   What if there's some super funky harmonic that develops in that particular location that backs the bolt out?  Maybe, since the bolt is not shouldered, it's fully threaded, that the interaction between it and the inside of the sleeve creates a dynamic that loosens the bolt (you can see the marks of the threads inside the sleeve in the photo).  Maybe a combination of all of those factors?  Danged if I know.  Are you telling me that you've never, ever, in your whole life, ever had a properly torqued fastener back off?  Like, ever?  I sure have.....  And, somehow I doubt that a TTY bolt is used on a shock mount......
Anyway, here's the deal: as I said earlier,  take it for what it's worth.  I'm just passing along my anecdotal experiences FYI.  Readers of the thread can check the bolt on their truck, they can even back it out and put some locktite on it just in case, it's easy to do.  Or not.  It's a lot easier in the driveway to find and check the bolt than it is on Black Bear Pass.
YMMV....
Actually, there's about a 1000 reasons. If what you said is true, things like loctite, special lock washers, safety wire and locking nuts wouldn't exist.
Rear shock bolts on pickups are especially susceptible to backing out, or getting loose, even when correctly torqued.  The best fix is to use additional methods to secure them.
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
    • If we're talking futures, yes, it's speculation.   The spot price of a delivered barrel is elevated now compared to before the conflict. And that is related more to current supply/demand.
    • SPECULATION on the wars effect raised prices. AI is maximizing the profit. Refining is vertically integrated.
    • It's the Middle East conflict that raised prices, not AI. But nice distraction.
