Assuming she whistles like crazy taking off? Sounds sick man. How much in cab drone driving down the road? I have the afe exhaust on mine and has no turbo noise whatsoever which sucks
Thanks man. Have you deleted the resonator at all? Idk what the afe exhaust consists of. After I did the muffler swap with the Borla Atak exhaust I couldn’t hear the turbo. I deleted the resonator and bam, she whistles Dixie now. Everyone tells me the turbo is really loud on it, I hear it out the window quite a bit but it’s not the same as hearing it go by. No there’s little to no drone, can still have a conversation with a passenger easily and not have to raise your voice. It’s really only loud when you get on it. Just normal driving all you hear is the turbo spool up and down mainly. Just got my 35’s on her yesterday too and it looks so good I couldn’t be happier!
The truck looks and sounds good! Do you have any videos of how it sounds when you rev it? Im between the Flow Super 10 and the Atak...
How annoying is the AFM shutting down 2 cylinders after installing an exhaust on these and how do you deal with it ?
2 hours ago, Mike Borowski said:
No one has tried the AFE tuner yet?
I have the AFI  tuner and intake on order.. The intake is on back order so I wont see that for a week or so. I ordered the Atak and should have that wed so Ill have some info shortly from my truck.
Please post vids after install.
  • 4 weeks later...
Sorry man I haven’t been on here in a while, no I don’t have any revving vids. I can guarantee you won’t go wrong with the Atak that’s all I know. I love it. Just make sure whatever you go with that you delete the resonator too so you can hear the turbo whistle good.
I don’t even notice the AFM on it at all. Like not one bit. I can never tell when it kicks in and it doesn’t make the truck sound different that I’ve noticed at any time
  • 3 months later...
Should be getting the turbo adapter plate for the diverter valve tomorrow. Once installed should be able to hear the BOV since it’ll be dumping to atmosphere rather then recirculating. Also just got the mud guard deletes in and installed. Clears the 35’s at full lock now and looks a lot better.
Can u post sound clips of the exhaust along with the part number. Im considering this too, if you say that AFM is not noticeable. When mine comes on it sound like a v twin missing.
  • 3 months later...
Has anyone thought about adding an exhaust cutout after the down pipe. used with a switch of course so you could be smooth or braaaap.  I read they add so much flow most turbo motors couldnt handle it but if ours is 1.5 bar already... thats what they were achieving when their motors after the install and then went boink.  Not sure if you can just add more fuel like diesel engines. Its a fun truck for sure and the whistle makes me smile on the way to work.
On 1/23/2020 at 6:47 PM, Timebombt said:
I’ve also reached out to turbo smart about a BOV. They’ve said if anyone is in the San Diego they need a vehicle to develop one. I move out there this summer but if anyone is out that way hit them up.
I'm just now seeing this thread for the first time.  I moved to San Diego back in September.  Although I don't have a 2.7, if love to see what comes out of this.
    • In the 6.6 gas thread, I added information in my fluid change thread about these gauges and temperatures. With very limited data, it so far looks like ~30 degrees difference between front and rear.
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
