Couple of 4wd Questions
Hi All. I have a 2019 Silverado 2500HD with the 6.0 gas and the transfer case selector on the dash. I live in Indiana and lately we haven't had really bad winters. I have a couple of questions regarding using my 4wd. First, at what speed can i safely engage 4wd from 2wd? I have heard that you don't have to slow down to do this in the newer trucks but i don't want to take a chance of damaging something. Second, what should be my maximum speed in 4hi? Obviously if i need 4wd i shouldn't be flying but i am curious what is safe for my drivetrain. Thanks for your input.
9 hours ago, davester said:
the answers to your questions will be in the owners manual.
I knew there would be info in the manual, just wondered if any members could give me some real world info. I know what is in the manual isn't always what has worked best for people. A friend that built these trucks for 30 years told me not to use the auto 4wd selection on my 2003 Silverado because GM had a lot of warranty claims because of them. Just wondered what others are doing.
I dont leave mine in auto.
it's either 2H (normally), 4H snow and what not, 4L stuck
My son left his in "auto" and a "service 4wd" message kept coming up.  Dealership said not to ride around like that every day on pavement, only when on dirt roads or such.
That is about to change if it hasn't already.
Interesting, I got the same message driving in snow/slush today.
2015-2019 HD doesn't have 'auto mode' 4wd
(yes, it's available on the 2020 models)
I frequently change between 2H and 4H during fall/winter.
My normal practice is to be foot-off-throttle when switching to 4H, so all wheels are running the same speed during the 4H engage.
What I avoid is engaging 4wd when the rears are spinning.
Never had any 4wd issues.
IMO, if it's safe to be running at speed xyz, then it's safe to do the switch at speed xyz.
Try to avoid forgetting to disengage the 4wd when you get to a surface with good traction.
key right here..!
when I had a S15 GMC Jimmy back in the 90's, I made a 300 mile road trip in 4H.. at 70mph..
(young and dumb)
Do you have some insight on the winter forecast for Indiana?
You're right, his is a 1500
OP says he has a "2019 Silverado 2500HD with the 6.0 gas and the transfer case selector on the dash".
Info about what happens with a 1500 doesn't answer is question at all... and just might add to his uncertainty.
Calm down Francis, just replying to  the OP's second post.  He said he was wondering what others are doing about the auto 4wd select and I am answering.
  • 3 weeks later...
This was definitely on a previous truck, I'm guessing it was my 2006 Titan, but I believe it was in the owner's manual that they recommended keeping 2WD to 4WD shifts under 60mph. Personally I've maintained that as a rule of thumb, but truth is these trucks have so many sensors and safeties built in, it won't complete the shift if doing so at your current speed would cause any issues.
Because it just happened to me I'll mention this scenario, even if you shift to 4hi at a stop, let it complete the shift before you get on her...I was at a light and put it in 4 so I could get off the line, but the light changed sooner than I expected. Rear spins, I let off, and *clunk* when it was able to get into 4WD. Doubt there's lasting damage from that one time but not something you want to make a habit of, to say the least.
Maximum speed in 4hi?!? Mash the throttle and find out LOL. I'm not positive but pretty sure I've had mine up to 85-90mph with no issues.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
